I am in the process of building a new PC with a full custom loop. Mobo is ASUS Maximus IX Extreme. Can I POST it without a cpu/vram cooler? attaching the included monoblock with an assembled loop would be a hassle just to verify that cup/mobo works. I've done it with an older generation cpu but vram had a heatsink and I had a case fan blowing on the IHS.
https://linustechtips.com/topic/853308-7700k-post-without-a-cooler/
I personally wouldn't, but its up to you.
Sync RGB fans with motherboard RGB header.
Main rig:
Ryzen 7 1700x (4.05GHz)
EVGA GTX 1070 FTW ACX 3.0
16GB G. Skill Flare X 3466MHz CL14
Crosshair VI Hero
EK Supremacy Evo
EVGA SuperNova 850 G2
Intel 540s 240GB, Intel 520 240GB + WD Black 500GB
Corsair Crystal Series 460x
Asus Strix Soar
Laptop:
Dell E6430s
i7-3520M + On board GPU
16GB 1600MHz DDR3.
it's safety features should kick in and throttle the living hell out of it... not the best idea though
desktop
r5 3600,3450@0.9v (0.875v get) 4.2ghz@1.25v (1.212 get) | custom loop cpu&gpu 1260mm nexxos xt45 | MSI b450i gaming ac | crucial ballistix 2x8 3000c15->3733c15@1.39v(1.376v get) |Zotac 2060 amp | 256GB Samsung 950 pro nvme | 1TB Adata su800 | 4TB HGST drive | Silverstone SX500-LG
HTPC
HTPC i3 7300 | Gigabyte GA-B250M-DS3H | 16GB G Skill | Adata XPG SX8000 128GB M.2 | Many HDDs | Rosewill FBM-01 | Corsair CXM 450W
2 minutes ago, tp95112 said:
I wouldnt, but if you really have to do as fast as you can and just shut off immediately as you see the logo. Better to be safe then sorry.
8 minutes ago, pwnograffik said:
You can post with it yes, but I don't recommend going any farther than that without a cooler.
So far consensus is to get a cheapo heatsink and cooler for the POST...
If I was in your position, I would assemble the water block you have to test it. Or just build the system and test then. Thats what I did.
Main rig:
Crosshair VI Hero
EK Supremacy Evo
Asus Strix Soar
Laptop:
Dell E6430s
16GB 1600MHz DDR3.
if you have an intel stock cooler around, or can find a cheapo $5 cooler on craigslist, literally anything designed to keep a cpu from burning to death, worth the few bucks
desktop
HTPC
It's fine, with the Monoblock you will have a small thermal headroom in the 1-3 seconds it takes to POST.  I do it with nothing at all occasionally, modern software has sooo many safety measures it's  not an issue
Want to custom loop?  Ask me more if you are curious
If this person can run Prime95 on a Haswell i3 without a cooler, I'm sure a Kaby Lake i7 would POST without a cooler. :) (Start at 19:35 if your platform doesn't auto cue.)
That gets me thinking .. I wonder how much throttling there'd be if someone ran Prime95 small FFT on a 7980XE with its heatspreader removed (but not replaced), at a location where the ambient temp is 50°C ....
i can't believe i'm telling this but i did this before with a i7 4790k.. i found a small tin pot and i filled it up with water and some ice kubes put that on the cpu(with paste on the cpu) and i could fix some bios issues.
it lasted for about 20min before throttling.
so there's that..
Specs: Ryzen 9800X3D 5425MHz - ASUS TUF RTX 4080 super - G.Skill Trident Z5 Neo 64GB 6400MT/s CL26 -  Gigabyte X870 AORUS Elite Wifi7 ICE - Torrent Fractal Design white - EVGA 850W Supernova G2 80+ Gold - Noctua NH-U12A
A modern CPU hits 100C in a matter of seconds, so no. If you want to know if it POSTs, by all means, put something on it. Even if it's some generic metal AMD heatsink from 2003 if you happen to have such a thing. It'll keep the CPU from overheating for at least another minute or so.
PC Specs - AMD Ryzen 7 5800X3D MSI B550M Mortar - 32GB Corsair Vengeance RGB DDR4-3600 @ CL16 - ASRock RX7800XT 660p 1TBGB & Crucial P5 1TB Fractal Define Mini C CM V750v2 - Windows 11 Pro
I think that the system would become unstable... So after watching this video, I'm just gonna install the heatsink but not connect it to the loop and try to POST - will give me a bit more thermal headroom prior to throttling
