I am planing to build a gaming computer. It will have a GTX 1080ti and will be housed in a Masterbox 5 pro RGB. I looked at the case and I think I saw a vertical PCI slot. I wanted to confirm that and if that is one, do I need to buy a bracket to support it or can it support itself? If it needs one what one should I get?
http://www.coolermaster.com/case/mid-tower/masterbox-pro-5-rgb/
https://linustechtips.com/topic/852975-vertical-pci/
Nope
13_fd78198d1f269edd7d6aa6226286125e_1506
That is NOT a vertical PCIe card bracket.
4 minutes ago, emosun said:
the cases expansion slot openings are on the back , I'm not seeing what you're seeing here
he's talking about this design
deepcool_atx_gamerstorm_bill_owen_mnpcte
Desktop benching:
https://linustechtips.com/topic/852975-vertical-pci/#findComment-10626014
The Masterbox 5 pro RGB does not support vertical GPU mounting...
CPU: i7-12700KF Grill Plate Edition // MOBO: Asus Z690-PLUS WIFI D4 // RAM: 16GB G.Skill Trident Z 3200MHz CL14
GPU: MSI GTX 1080 FE // PSU: Corsair RM750i // CASE: Thermaltake Core X71 // BOOT: Samsung Evo 960 500GB
STORAGE: WD PC SN530 512GB + Samsung Evo 860 500GB // COOLING: Full custom loop // DISPLAY: LG 34UC89G-B
https://linustechtips.com/topic/852975-vertical-pci/#findComment-10626021
If you want to vertically mount a GPU what you require is the vertical GPU adapter that fits in the current PCI-E opening.
http://www.coolermaster.com/case/case-accessories/vertical-graphics-card-holder-kit/
https://linustechtips.com/topic/852975-vertical-pci/#findComment-10626118
19 minutes ago, navi6155 said:
I checked the case and it only has 6 PCI slots but the vertical GPU adapter needs 7. Is there any other GPU adapter you could recommend or is there anything else I could do.
nvm I read it incorrectly
Computer engineering PhD student and RFML researcher
Daily Driver:
CPU: Ryzen 7 4800H | GPU: RTX 2060 | RAM: 32GB DDR4 3200MHz C16 | OS: Debian 13
Gaming PC:
CPU: Ryzen 5 5600X | GPU: EVGA RTX 2080Ti | RAM: 32GB DDR4 3200MHz C16 | OS: Windows 11
https://linustechtips.com/topic/852975-vertical-pci/#findComment-10630481
You are mistaken, ATX boards have a minimum of 7 expansion slots. From the back it doesnt look like a normal PCI slot, but it is. You can tell by looking at the side and seeing it has  a thumb screw
https://linustechtips.com/topic/852975-vertical-pci/#findComment-10630808
  • 1 month later...
1 hour ago, AlbertW035 said:
What case is that??
idk, just found the picture on the internet.
Desktop benching:
https://linustechtips.com/topic/852975-vertical-pci/#findComment-10801992
What that case cost plus the add on kit they stick you with you can buy a different case like http://www.thermaltake.com/Chassis/Full_Tower_/View/C_00003130/View_71_Tempered_Glass_RGB_Edition/design.htm
Or http://www.lian-li.com/alpha-550/?preview=true
Or thumb around themaltake they off many cases with vertical mounted gpu.But keep this in mind if your air cooling that gpu most vertical mounted gpus are kinda close to the side so air flow can be a problem.If its going to be water cooled its no problem and gives you something to look at.
https://linustechtips.com/topic/852975-vertical-pci/#findComment-10802376
