Using a single 8pin cable for a 1080ti
GGNN
Hi there!
I just got my MSI 1080ti gaming x yesterday, and little did I know the box didn't include anything but the card and a 6pin to 8pin adapter! (I didn't even get a code to download a free game... I don't know what's up with that).
Anyways, the cable I used to power my old 660 was a single 6pin, and I was left with an extra 2pin dangling on the side, plus another 6pin+2pin on that same cable. I used that cable to power my new 1080ti since I didn't have a spare 8pin and really wanted to try it. Should I be worried about using a single cable to power a 1080ti? It seemed to be working fine, I played for little over an hour on BF1 and everything was running smoothly, the card was silent.
Would be helpful to know what Power Supply Unity you actually have.
Personal Desktop":
Luna, the temporary Desktop:
All I know is it's 750w, I'll be able to tell you more when I get home in a few hours.
You should be fine for the most part, the GTX 1080 Ti despite being a powerhouse it handles energy with amazing efficiency, so as long as it isn't lacking and it shouldn't with 750w PSU you're probably fine... I won't get into the merit of quality though just of usability.
Personal Desktop":
no codes in the box any more - you should have gotten an email with the code in it.
so that's two 6+2 pin connectors on a single cable - if the PSU is designed that way, i see no reason why it should not be ok.
I didn't get anything but the delivery confirmation. Who should I be complaining to, then?
Amazon, MSI or Nvidia?
Man, I could have gotten either Shadow of War or Destinity 2, both of which I'm looking forward to play :'(
try asking the amazon seller first
it should be fine but JaysTwoCents showed that daisychains can impact performance on NVIDIA cards a little while ago. if you can id say run another cable
Builds:
I guess I can just buy an extra one, yeah, I still have room on my PSU. But a single cable will have to do for now.
If it looks like this from the psu  then you are fine.
Try using the PSU Tier List!
How to reset the bios/clear the cmos
My current rig:
CPU: Ryzen 7 3700x
Ram: 1x16gb DDR4, 2x8gb DDR4
Storage: 1tb nvme ssd
GPU: gtx 3080
Monitor: 23.8" Dell S2417DG 144hz g-sync 1440p + 27" Acer S271HL 60 Hz 1080p
Keyboard: ducky one I | I SF
Mouse: gpro wireless | glorious model o2 wireless
Sound : beyerdynamic 1990 pro | Monoprice liquid spark (amp) + topping d10 (dac)
That's exactly what it looks like, except that for the second 6+2, I used the 6 to 8pin converter included in the GPU, otherwise the cable was too short (it's one of those with thick twisted fabric around it, so I couldn't really twist or stretch it enough....)
As long as you aren't daisy chaining (hooking up 2 or more to one source) then you are fine, that's basically just a cable extension if I read that correctly.
My current rig:
CPU: Ryzen 7 3700x
GPU: gtx 3080
no? thats still basically the same thing. what you want is a compleatly separate cable from my understanding. not that that wont work,  but for the best results you want two discrete cables
Builds:
That's why I said "from the psu" to not confuse him with the splitter I put in
My current rig:
CPU: Ryzen 7 3700x
GPU: gtx 3080
Just an aside, I run a single cable from my psu (seasonic 750) to both my R9 390's 8pin ports & it's been great.
I asked this when I got my card & was told it was standard practice.
Think if a 390 can run off a single, a 1080 should be good.
12 hours ago, JusticeBeaver said:
If you have Gmail check your spam or update folder....
13 hours ago, kk027 said:
This happened to me with the 1060 6GB. It turned out that the code was e-Mailed to me.
I checked, and I got nothing.
Is it possible that since the offer wasn't specifically mentioned on the product page the day I bought the card, I might have missed it? (it's mentioned pretty much everywhere else)
It's a 1080ti but yeah I went to a computer shop yesterday and the guy said that running a 1080ti with a single cable is absolutely fine as long as both 8pins are plugged on the card.
I got my 1080ti from amazon in the summer with no code
a week later amazon had the 1080ti with destiny2 bundle so I called them and they gave me a 40 voucher to buy the game
1 hour ago, kk027 said:
Well, I guess that the retailer you used didn't offer the code.
The retailer is amazon.
Ok, hopefully something like that can happen for me too.
destiny 2 bundle was back for a limited time at the start of the week
You don't get emails anymore, I believe you need to register with GeForce experience or something to get it.
Make sure to quote me or tag me when responding to me, or I might not know you replied! Examples:
Do this:
Quote
And make sure you do it by hitting the quote button at the bottom left of my post, and not the one inside the editor!
Or this:
@DocSwag
Buy whatever product is best for you, not what product is "best" for the market.
Interested in computer architecture? Still in middle or high school? P.M. me!
I love computer hardware and feel free to ask me anything about that (or phones). I especially like SSDs. But please do not ask me anything about Networking, programming, command line stuff, or any relatively hard software stuff. I know next to nothing about that.
Compooters:
Desktop:
CPU: i7 6700k, CPU Cooler: be quiet! Dark Rock Pro 3, Motherboard: MSI Z170a KRAIT GAMING, RAM: G.Skill Ripjaws 4 Series 4x4gb DDR4-2666 MHz, Storage: SanDisk SSD Plus 240gb + OCZ Vertex 180 480 GB + Western Digital Caviar Blue 1 TB 7200 RPM, Video Card: EVGA GTX 970 SSC, Case: Fractal Design Define S, Power Supply: Seasonic Focus+ Gold 650w Yay, Keyboard: Logitech G710+, Mouse: Logitech G502 Proteus Spectrum, Headphones: B&O H9i, Monitor: LG 29um67 (2560x1080 75hz freesync)
Home Server:
CPU: Pentium G4400, CPU Cooler: Stock, Motherboard: MSI h110l Pro Mini AC, RAM: Hyper X Fury DDR4 1x8gb 2133 MHz, Storage: PNY CS1311 120gb SSD + two Segate 4tb HDDs in RAID 1, Video Card: Does Intel Integrated Graphics count?, Case: Fractal Design Node 304, Power Supply: Seasonic 360w 80+ Gold, Keyboard+Mouse+Monitor: Does it matter?
Laptop (I use it for school):
Surface book 2 13" with an i7 8650u, 8gb RAM, 256 GB storage, and a GTX 1050
And if you're curious (or a stalker) I have a Just Black Pixel 2 XL 64gb
