Help with ups
MikeDev
I need to buy a ups for my pc, ill be using th ecorsair AX 860 w psu, plan i buying the APC BR1500G UPS. I read that i need a UPS with pf correction to be compatible with it. Can any one tell me if this is true or will the ups work?
you mean a PSU?
Case: Corsair 460X RGB bby, CPU: I5 8600K, Motherboard: MSI B360M PRO-VDH, RAM: 8GB Hyper X 2400MHz , Graphics Card: GTX1060 6GB, PSU: Corsair RM750x,
Cooler: BEQuiet!  Pure Rock Slim SSD: Kingston 240GB, HDD: 2TB Seagate Barracuda
you mean a PSU?
no a UPS is different, it stands for Uninteruptable Power Supply. now i just need to figure out what it does...
AMD FX 8350 8-Core CPU (Stock 4GHz) | Gigabyte GA-990FXA-UD3 | (Rev. 4.0) | 8GB 1600MHz HyperX Fury | AMD R9 270 (MSI Gaming OC Edition) | NZXT H440 (White) | Kingston 120GB SSDnow V300 | Seagate Barracuda 1TB (7200 RPM) | Corsair RM750m 750w Fully Modular Power Supply
Dell 23.6-Inch 1080p 60hz IPS Display | Corsair H100i AIO Liquid Cooler | Logitech G710+ Mechanical Gaming Keyboard | Logitech G502 Proteus Core | iSymphony Wireless Stereo Speakers | Windows 8.1 (64-bit)
Oh its for back up power its like a PSU and a huge battery in case of power cuts and stuff
ok, that's what i suspected.
in regard to the original post, here is a ups that is quite well reviewed, ive never used one, so i dont know how well it works but it looks pretty good. http://www.amazon.com/APC-BE550G-Back-UPS-Outlet-550VA/dp/B0019804U8/ref=sr_1_1?s=electronics&ie=UTF8&qid=1386280124&sr=1-1
The power is too small on this one :/
You want the wattage of the ups to me equal to or greater than your psu
Also dont cheap out and buy a modified sine wave ups make sure you buy a pure sine wave one. Tp-link had some decently priced ones last time I looked.
Thanks, can u link me to one?
  • 2 weeks later...
yea sorry here ya go http://goo.gl/bUF1ew i think i actually meant cyberpower not tp-link, my bad http://goo.gl/PbRWB1
