Graphics card is touching cpu air cooler
Solved by Glennieboyyy007,
2 minutes ago, Jason_Tan_ said:Here is what it looks like.
looks like it is resting a very small bit on it, but it shouldn't put any real pressure on it. also it's only touching on the shroud (gpu) with the parts of metal (cpu cooler) that are the most away from the heat, so i dont think it will cause any problems
Share
Followers
2
