Dark rock 3 with ryzen 1600 @55c load normal?
JohannesStopczyk
Just wanted to check because with the stock cooler was @60c at 100% load and with no more noticable sound.
CPU:Amd fx-8320 Motherboard:Gigabyte GA-970A-DS3P RAM:Hyper x fury ddr3 8gb 1866 mhz GPU:Amd Asus radeon r9 280 3gb Case:Fractal design define r4 Storage:1.SSD hyper x fury 120gb 2.HDD seagate 500gb PSU:Corsair CX 600M, 600W Monitor:Some random philips monitor Mouse & keyboard:CM Storm Devastator - MS2K & MB24 OS:windows 7 home premium.
Is this a synthetic load, or you just watching temps while gaming?
55-60c isn't bad for load temps, I really wouldn't expect it to get much cooler without going way overkill on cooling.
Its with Aida 64, haven't really watched them while under gaming load
do a gaming load, see what temps you get. it might be lower.
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
10 min cs go deathmatch @42c highest 20-25% load
Any more demanding games?
Intel Xeon 1650 V0 (4.4GHz @1.4V), ASRock X79 Extreme6, 32GB of HyperX 1866, Sapphire Nitro+ 5700XT, Silverstone Redline (black) RL05BB-W, Crucial MX500 500GB SSD, TeamGroup GX2 512GB SSD, WD AV-25 1TB 2.5" HDD with generic Chinese 120GB SSD as cache, x2 Seagate 2TB SSHD(RAID 0) with generic Chinese 240GB SSD as cache, SeaSonic Focus Plus Gold 850, x2 Acer H236HL, Acer V277U be quiet! Dark Rock Pro 4, Logitech K120, Tecknet "Gaming" mouse, Creative Inspire T2900, HyperX Cloud Flight Wireless headset, Windows 10 Pro 64 bit
I played dead by daylight and got similar results
I never asked about when gaming, was just asking about when under 100% load
Most coolers perform very simarlarly when under 100% load. The biggest differences can only really be seen on higher tdp parts where lower end coolers fall away.
Gamnmg is a real world work load, so I would use those temps with 60 being worst case scenario.
only had about 40 when gaming
is the cpu operating at stock speeds or OC'd, what are ambient temps?
desktop
r5 3600,3450@0.9v (0.875v get) 4.2ghz@1.25v (1.212 get) | custom loop cpu&gpu 1260mm nexxos xt45 | MSI b450i gaming ac | crucial ballistix 2x8 3000c15->3733c15@1.39v(1.376v get) |Zotac 2060 amp | 256GB Samsung 950 pro nvme | 1TB Adata su800 | 4TB HGST drive | Silverstone SX500-LG
HTPC
HTPC i3 7300 | Gigabyte GA-B250M-DS3H | 16GB G Skill | Adata XPG SX8000 128GB M.2 | Many HDDs | Rosewill FBM-01 | Corsair CXM 450W
Anything under 70°C for Ryzen at full load is just fine.
I'm using Dark Rock 3 with my R7 1700 ... at stock setting sit would go to 62°C when stress testing with aida 64 (cpu + fpu + cache).
When OCed to 3,8GHz on all cores, it gets up to 75°C under full load.
Like I said ... if it's below 70°C you are more than fine. If it goes higher ... could be a problem.
Ask someone else, what's highest safe temperature for Ryzen ... I have no idea if it's 90°C or lower.
Intel i7 12700K | Gigabyte Z690 Gaming X DDR4 | Pure Loop 240mm | G.Skill 3200MHz 32GB CL14 | CM V850 G2 | RTX 3070 Phoenix | Lian Li O11 Air mini
Samsung EVO 960 M.2 250GB | Samsung EVO 860 PRO 512GB | 4x Be Quiet! Silent Wings 140mm fans
WD My Cloud 4TB
Normal temps. You can only go so low with air. Like said, you would see bigger difference if you'd overclock.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
Ok so its not only me ok thank you a lot.
