Problem with PSU not powering GPU under load
Just now, GymothyCharles said:-snip-
the sound it makes, is it the game sound freezing or does it come from your computer case? if the latter, can you record it?
i don't think it's your PSU, if it was, your computer would turn off immediately if it was.
you might be hitting half your psu wattage at maximum peak (running aida64 and furmark and some other tasks as well simultaneously) so i severly doubt it's your psu.
also if you only have one game to go by, (is it even final build?) it's not really solid evidence for anything really..
try reinstalling the game with a fresh download. same thing?
run 3dmark or catzilla or unigine benchmarks or all of them if you want and some other gpu intensive games if you have..
if it passes those, try furmark for a little while (watching temps).. if nothing happens, it's something with the game.
