Parts for a quiet build?
Depends on what you're cooling, how quiet, etc. But largely Be Quiet! products are not particularly noteworthy, though some of it is pretty good.
Fans are actually relatively unimportant here because you don't want to be running anything at a mid to high rpm anyway, and most decent quality stuff is similar down in the lower ranges, with many exceptions.
For sure you need to plan on having a quiet power supply, as you can't control its fan speed curve later. You need something quiet up through the power draw/temps you'll be using. That could be a fanless model, something with a fanless mode through the power draw you'll see, or just something that only spins slowly with a reasonable quality fan through the loads you'll encounter (e.g. 600 rpm on a 12 cm fan).
The main problem for a lot of builds is cooling the GPU quietly. How feasible this is depends on how many graphics cards you're running (2 and definitely more than 2 might only really work with custom watercooling), the power and temp targets and overclocks and so on. Ideally for low noise you would undervolt and run at lower power levels. The right model graphics card, if sticking with air cooling, is a must. Some are much quieter than others for a given temp target. Check TechPowerUp reviews, among others. Either that or you'll want an aftermarket cooler for that, in which case you need a model with a layout supported by the aftermarket cooler.
CPU cooling is another big problem if overclocking substantially. If not, a decent aftermarket cooler and that is probably fine running a low fan speed curve. Ideally you get a better model but it's not like you necessarily have to run an NH-D15 or similar top-tier air cooler unless you're trying to max your overclock under a given noise constraint. Something closer to $30-40 could be okay, but if overclocking or using a high-end-desktop chip, be wary of fans/coolers tuned for performance at a budget where the acoustics of the fan are relatively lousy (e.g. CM Hyper 212 variants and so on).
If the rest is quiet, actually the loudest components may be any hard drives. You definitely want as few mechanical drives as possible, and you want them to all be 5400 rpm (or I guess 5900 rpm), preferably with fewer platters. Unfortunately not many especially these days review hard drives for noise. Ideally you would elastic suspension mount them to remove any vibration transfer, but a decent drive-mounting mechanism may be acceptable. There are some aftermarket solutions for dampening drives as well. Well, if "no budget" means "budget is no object" then I'm sure you can use all SSDs.
Generally, the key to low noise to have low-noise components, not to smother higher-noise components with a closed-off, sound-dampening case, though that also works to an extent. If you don't have any mechanical hard drives, an alternative case strategy can be to use a very open, free-flowing case—if everything inside is quiet, the build would then be quiet. If you have mechanical drives (or dealing with coil whine, as suggested below), then using a more solid and sound dampening case is usually a better idea.
Whatever case fans and CPU cooler / other stuff you have, you want all to be software controlled based on temps, probably, maybe with fans turning off at low enough temps, Asus tends to have full control, both PWM and voltage, across fan headers. Some others may these days too.
