graphics card Core2Quad Workstation Machine with 6 Pin GPU Connector
On 8/10/2017 at 11:27 AM, StarboyXO said:Hello to everyone
My friend is facing a problem regarding his Workstation PC ( HP Elite 8000 MID TOWER/Core2Quad ) Since he had no money to buy anything, He requested his relative to buy him a new graphics card which he did got from him, "MSI GTX 1050Ti GamingX". Now the problem he's facing is that his PC doesn't support the 6 Pin Power Connector which that GPU requires.As i told he can't afford any big upgrade to other machines, cpu e.t.c, He just wants the same alternate Workstation Core2Quad Tower which can support 6pin connectors and might having a bigger supply(Not important as the gpu requires 300 Watts). I whould be thankful if someone can look up Workstaion computers for these suggested requirements.
Please don't give advices for changing GPU cuz he likes the MSI variant of the card and wants to play with it and Dont say on upgrading to higher Cases,motherboards or cpu as i have told that there is no budget.
Waiting for your response
Peace <3
IIRC, the PSU in the Elite 8000 uses a proprietary MB connector. If I'm recalling that correctly from the Elite 8000 that I flipped, a new PSU would require an adapter--but they do make those adapters.
The thing about Molex connectors, and why I do not recommend them in the slightest, is that any PSU ships with the connectors the OEM intends for you to use already built in. If your power supply doesn't have a PCIe connector already, it's because the OEM didn't design that PSU with the demands of a GPU in mind. It's entirely possible that you use the adapter for a year or more with nothing happening, as I've done with a cheapo Core 2 Duo system that I genuinely did not care about, but it's also possible that a cheaply-built Molex-to-anything adapter shorts out, fries something and/or catches fire. No joke.
The topic of Molex-to-SATA came up earlier. I think this was a typo, but I feel compelled to say it all the same: Molex-to-SATA, lose all your data. M2S connectors are very prone to shorts, overheating and fire., any one of which can damage the PSU, whatever it's connected to, your motherboard itself, hell, even your house if you're really unlucky.
To your original question, I would say that your friend is skunked based upon his original parameters unless I'm wrong about the proprietary PSU. If I am, change the PSU to something better and you're done. If I'm not, there are three options I see:
1. Trade out the Gaming X for this MSI model, which doesn't need a 6-pin. If the built in PSU is 320W, your friend is fine.
2. Find a PSU adapter so you can replace the PSU entirely with something more appropriate for the use case (CX450M would be more than enough)
3. Sell the entire PC (nuclear option) and replace it with one that supports an aftermarket PSU
