Trouble decicing on fans
dcgreen2k
I am looking for 2 high static pressure fans that will work with a corsair h100i dual rad. I've found some nicely priced corsair fans, but people have told me to stay away from them; is this justified? Another fan that I've considered is the Bequiet Pure Wings 2 120mm PWM. However, they don't have red leds... Do you guys know of any good fans?
I need:
120mm
Quiet operarion
Red or RGB leds would be nice
4 pin PWM would also be nice
Your input will be appreciated!
Computer engineering grad student, cybersecurity researcher, and hobbyist embedded systems developer
Daily Driver:
CPU: Ryzen 7 4800H | GPU: RTX 2060 | RAM: 16GB DDR4 3200MHz C16
Gaming PC:
CPU: Ryzen 5 5600X | GPU: EVGA RTX 2080Ti | RAM: 32GB DDR4 3200MHz C16
Thermaltake Ring has good fans (RGB and red leds too)
Im mostly on discord now and you can find me on my profile
My Build: Xeon 2630L V, RX 560 2gb, 8gb ddr4 1866, EVGA 450BV
My Laptop #1: i3-5020U, 8gb of DDR3, Intel HD 5500
I'm quite satisfied with my Corsair SP120 PWM fans tbh. They are pretty quiet and are going strong for at least 1.5 years now.
