Ghost S1 Case
GHOSTKILLERS24
So i am going to be getting the ghost s1 case when it comes out it supports coolers up to 63mm in height and i will be running a Ryzen 1800X in it what is the best performing cooler i can fit in that space? I am also running dominator platinum ram so it has to fit with that they are kind of tall
I think the stock cooler is 54mm or something isn't it?
Other than that you're best bet is the Noctua...something x65.
The case has been revised to fit 65mm coolers, as well as small AIOs.
You won't be running an 1800x in that chassis. It simply can't handle the heat.
Welcome to the forum!
Storage: WD 750 SE 500GB, WD 730 SE 1TB GPU: EVGA RTX 3070 Ti PSU: Corsair SF750 Case: Streacom DA2
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
