NZXT H440 Integrated 8-port PWM
By
MaxCharbon
in Cooling
in Cooling
Solved by Jonathan Lemmens,
4 hours ago, MaxCharbon said:Should I just get a PWM controller for the 4pins and use the Hub for the 3pins?
I'd say this is the best option, you can plug 3-pin fans into a PWN fan splitter without issues but they will just run at max rpm.
Featured Topics
Marie Rose ·
Posted in Cases and Mods0 -
8
1
G9XFTW ·
Posted in Laptops and Pre-Built Systems7 -
7
fade2black001 ·
Posted in Troubleshooting0 -
3
2
37
BifrostCrow ·
Posted in Troubleshooting4
