X370 Taichi USB and MoBo lights on when PC is turned off
Solved by AniChatt,
Th
22 hours ago, lFaust said:Will do, thanks!
EDIT: I searched through all the different BIOS sections and didn't find anything like that. Though I did find a post of someone claiming that the ability to disable USB power will be added in a future BIOS update over on the AsRock forums.
Thant's great...wait for that update. However it is only that option which can disable power after shutdown in usb.
