HELP I DONT KNOW WHAT TO DO
By
Guest
in Custom Loop and Exotic Cooling
Solved by chris76816,
The H110i is an aio. That means that it does not need to be filled with water. All you have to do is mount the radiator and fans to your case and mount the cpu block to your cpu using the appropriate socket bracket.
Featured Topics
naldo29 ·
Posted in Troubleshooting0 -
1
MahdiC ·
Posted in Networking1 -
1
Sychicyuto ·
Posted in Troubleshooting2 -
ItzEager ·
Posted in Troubleshooting3 -
TheIndecisiveMollusk ·
Posted in New Builds and Planning1 -
4
Agall ·
Posted in CPUs, Motherboards, and Memory4
play_circle_filled
Latest From Linus Tech Tips:
I Am Not Buying A Super Computer - WAN Show May 3, 2024
