4-way SLI & CPU Block + Rads, How many D5s in what configuration?
1 minute ago, For Science! said:Need to tap into the knowledge of the old timers, I know 4-way SLI is not a thing now, but we scientists have our reasons to do so.
Has anybody done a loop with 4 GPU blocks and 1 CPU monoblock + lots of rads?
Is it even possible to have it in a single loop? Can you get away with 2x D5s in serial? or perhaps 4x D5s in serial......
Or must it be a dual-loop? This feels a little bit inefficient because the tradiational way to split will be 4x GPU and the CPU, where the GPU loop will still be restrictive AF. On the other hand setting up a loop with 3x GPU and 1xGPU+CPU sounds a bit annoying to route.
You should be good with a single D5 still but running at high speed, for silence dual D5 in series would provide enough pressure even when on low.
Dual loop are more for aesthetics than performance since you distribute the heat throughout all the possible rad space in the loop in a single large loop.
