Cleaning off dust using a paintbrush :/
Solved by themctipers,
2 minutes ago, Memorizer said:I stand corrected. It turns out there is more dust than I expected.
the easiest thing to do is just to take everything out (don't need to take apart CPU cooler from motherboard or the GPU from the motherboard, just take out the motherboard and the SSD/hdds) and then use a toothbrush and scrub everything in the case.
Cleaning fans is a bitch, luckily for me I am using cheap fans and I don't care if they die so I just rince it out with hot water and spin it to get all the fins clean.
