Are my Razer Adaro DJ's deffective or need more power?
Solved by Dackzy,
10 minutes ago, Black_Vanguard07 said:Whoa, YIKES, I honestly didn't think 7 dB would be that much of a difference. However, I'm a little confused. Why do the Adaro Dj's sound worse than the kraken pro's while the pro's are pulling more power?
power needed != quality. You probably just like the signature of the pro's or you got a broken pair.
either way, just return them and then maybe look through this list, there are lots of different headphones with different signatures.
