Smaller (40-50mm) Fractal Design Fan Failure!
iamdarkyoshi
Anyone used Fractal Design's smaller fans? I decided that because they were in the upper range of cost on newegg (like 9$ per fan!) And they were from Fractal, I'd buy them hoping for a long lifespan.
But... One just failed and its had about 24 hours of runtime! Its making lots of noise and hardly spinning.
What gives?
all products, no matter from who, sometimes are defective.
just RMA it.
QUOTE/TAG ME WHEN REPLYING
Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It.
If I'm wrong, please point it out. I'm always learning & I won't bite.
Desktop:
Delidded Core i7 4770K - GTX 1070 ROG Strix - 16GB DDR3 - Lots of RGB lights I never change
Laptop:
HP Spectre X360 - i7 8560U - MX150 - 2TB SSD - 16GB DDR4
I've had over 4 of their 40mm fans, they don't last very long.
They started making noise a few weeks or months after buying, but I kept buying it because it was part of my PC's aesthetics.
If you don't care about looks go with the noctua 40mm fan, it is extremely silent and much more reliable.
Just now, iamdarkyoshi said:
Can't, had to solder my own wires on it to use it on my 3D printer
well... I guess that you're gonna have to take the L on this one then.
but it's not specifically fractal's fault. everyone has defective products sometimes.
Desktop:
Laptop:
