water cooling Id cooling's water coolers any good? SYSTEM BUILD
7 minutes ago, potoooooooo said:DDC is not one of the worst pumps, it's still a laing pump and just because it's design is backwards doesn't mean it's a bad pump. It still works great and is perfect for stuff like the Predator because of it's small size. For that application, it is the best pump available. Full stop. The D5 is too big, and anything else like that alphacool pump is too weak to do anything worthwhile. And just because you don't like the predator form factor doesn't make it bad. It's not meant to be expanded on with radiators or different pumps, it's so you can attach a GPU to it. That's it. A DDC is perfectly adequate for even large loops, other than it having worse reliability i don't know why you could ever dislike it.
1) it's loud
2) it runs hot
3) it has bad reliability
4) even worse, when it's stuck to a radiator like in the Predator all the vibrations get directly transfered to the radiator and your case because there is 0 dampening. Again, makes a ton of vibration and noise.
Being loud and unreliable is the worst thing you could want in a watercooled PC.
PS- a lot of people but an expandable AIO as a way of getting into custom loop cooling, and since half the parts are crap then they end up spending more to replace everything when they could have just bought a custom loop from the start with all good components.
