So.. There's this girl I've been crushing on for several years now, sob story I know, anyways, I owe her a lot because despite me crushing on her, I give her a hell of a time because I'm a pretty shitty friend, and she puts up with me. That's the long and short of it and I wanna get her something really good this christmas. Her PC currently is some left over business system her boyfriend's mom had lying around that I reformatted and got going for her, and my initial plan was to upgrade it with a graphics card.. But I have a better idea. I'm going to build her a PC, and this is my current build http://pcpartpicker.com/p/26hF9
Tell me what you think.
Current Build: Intel i5-3570k @3.8GHz; MSI-Z77-G41; 8GB Corsair Ballistix @1600MHz; EVGA SSC GTX 650TI 2GB; Adata SX900 128GB; Western Digital Green 1TB; Asus CD burner; Corsair HX750 750 Watt power supply; Cooler Master HAF-912.
https://linustechtips.com/topic/78850-christmas-crush-help/
Whats the max budget?
Hope I could help!
Specs: CPU: AMD FX-8320 @4.0ghz GPU: ASUS DCUII GTX 770 PSU: EVGA Supernova 750g CASE: Fractal Define R4 RAM: 8 Gigabytes ADATA 1333 Mhz MOBO: GIGABYTE GA-990FXA-UD3
https://linustechtips.com/topic/78850-christmas-crush-help/#findComment-1082420
doooode
you are going to get friend zoned SOOOOOO hard
Main Rig: -FX8150 -32gb Kingston HyperX BLUE -120gb Kingston HyperX SSD -1TB WD Black -ASUS R9 270 DCUII OC -Corsair 300r -Full specs on Profile
Other Devices: -One Plus One 64gb Sandstone Black -Canon T5 -Moto G -Pebble Smartwatch -Nintendo 2DS -G27 Racing Wheel
#PlugYourStuff - 720penis - 1080penis - #KilledMyWife - #LinusButtPlug - #HashtagsAreALifestyle - CAR BOUGHT: 2010 Corolla
https://linustechtips.com/topic/78850-christmas-crush-help/#findComment-1082422
What does she use it for?....
Gaming.
I was thinking around $600, I'll be working minimum wage up until Christmas and it's going to be a hell of a feat if I pull this off, but, if I can.. I dunno, I'll feel all tingly inside and somehow or another it'll be worth it.
https://linustechtips.com/topic/78850-christmas-crush-help/#findComment-1082427
doooode
Waaaaayyyy ahead of you there, my friend.
https://linustechtips.com/topic/78850-christmas-crush-help/#findComment-1082430
doooonnntt do it!
Ask her out, if she says yes, THEN do it. or else it will be a waste of $1k!
https://linustechtips.com/topic/78850-christmas-crush-help/#findComment-1082438
Possibly cut a bit of the monitor and possibly put that money into the GPU
Hope I could help!
https://linustechtips.com/topic/78850-christmas-crush-help/#findComment-1082447
I was thinking about that.. She probably has a monitor at home, but I figured if I was on PCPartsPicker might as well play out all of the possibilities.
You're 18 and can afford to build a girl that you have a crush on a PC? Sounds a bit made up.
If you want advice with a system, go over to the new builds and planning section and you'll get all of the help you need. Good luck!
It's not really advice on building the system I need.. It's more.. The presentation and getting talked into or out of it before I flush a new truck, car, or apartment down the drain for a few more months lol.
https://linustechtips.com/topic/78850-christmas-crush-help/#findComment-1082469
Thats a fail. Soo much time and you didnt asked her and from what you said she had/have a boyfriend. Youre loosing it dude.
Buying her a PC to get her attention? Ohh dude... Why not screw her and give her that 120$. IF and only IF she was your girlfriend you date at least a year! you could put some much cash into. This is just waste of money. I dunno how you do it in Kentucky, but here we ask girl out and if she says "no" we to move another one and not buy her a $$$PC only because you like her...
TL;DR
DONT BUY HER THE PC AND ASK HER THE FUCK OUT
<p>Eryi's Action Rule#2 - "Dont jump on the green mushroom"
Ministry of StopIt!
https://linustechtips.com/topic/78850-christmas-crush-help/#findComment-1082548
I understand your point (been there, done that). But don't do it. She won't love you for you, she will love you for the things you buy her.
https://linustechtips.com/topic/78850-christmas-crush-help/#findComment-1082625
If you don't even know if she has a monitor at home, that means you've never been in her home. I wouldn't even consider building a computer for some girl that you've been "crushing on" for years. Maybe if you literally start living together and get serious, but it sounds like you think buying her a computer is the way to win her heart and that's just incorrect.
Take care of things you need first. Car, apartment, whatever. Ask her out, sure... but I would say do NOT go and buy some girl that isn't even your girlfriend a PC.
https://linustechtips.com/topic/78850-christmas-crush-help/#findComment-1082633
Well, she's not really a dating option regardless of what I do at this point.. She's just a really good friend I want to do something for. She doesn't have the best luck with electronics, and I'm hesitant to buy her anything with how faulty her electricity really is, but, I feel like she deserves a PC she can play games on and actually enjoy using, considering most of what she's had has been absolute shit. So how about instead of a full system I just rebuild one of my old ones for her? I have an old Dell Dimension E300 sitting in my closet collecting dust, with a GT 640 and some RAM it would be a decent little gaming PC.. And as a Christmas present I don't think it would be too bad.
https://linustechtips.com/topic/78850-christmas-crush-help/#findComment-1082678
You know, asking her out on Christmas would be a far better gift than buying her a new PC.  ;)
Delltopia
Case & Mobo: Stock Dell Optiplex 7010, CPU: i5 3470, RAM: 16gb 1333 DDR3 (1x8gb Corsair Vengence, 2x4gb Random), GPU: Diamond Radeon HD 7970,
PSU: EVGA GQ 650W, SSD: Kingston v300 128gb (OS), HDD: 700gb Seagate 7200rpm (Storage)
https://linustechtips.com/topic/78850-christmas-crush-help/#findComment-1082696
Do this and ask her out.
https://linustechtips.com/topic/78850-christmas-crush-help/#findComment-1082697
dont do it ask her out to dinner if she is single and go from there if she says yes buy her a gpu if she says no get her a necklace or some earrings take it from me dont buy a crush something expensive until you know their feelings
its GE (pause) TechNicks
my rig plus everything i have bought for it http://pcpartpicker.com/p/30sNV
https://linustechtips.com/topic/78850-christmas-crush-help/#findComment-1082699
she's not a prostitute. I think it's a bad idea...especially if she has a boyfriend. move on original poster...stop wasting your money.
He's not going to waste any money since he already has the PC and will only be transplanting parts...
https://linustechtips.com/topic/78850-christmas-crush-help/#findComment-1082846
I think you to to re-read his post. Not only does she already have a boyfriend, he's going to build a pc for her with his own money.
https://linustechtips.com/topic/78850-christmas-crush-help/#findComment-1082864
