hey, so i thought my 1600 was stable at 4ghz at 1.41/1,44 [ it flickers between] as it passed a aida 64 cpu stress test for several hours and r15 5 times in a row and iv been gaming on it for weeks now with no problems, edited my first video today and when it was being rendered my pc monitors jsut went black fans and everything were still spinning but nothing on screen so i had to hard shutdown and reboot, no errors came up it just booted right up with the same oc, when i dropped the cpu to 3.9 it worked fine for the rendering in lighjtworks
so question is do i push the llc to lv 5 on my board to keep the voltage at 1.439 or do i drop the mulitplier to 3.9 ?
i wont be rendering that much i dont think maby a few times a week.
do you think there is much gaming performance to be lost at 3.9 vs 4 ghz ?
what would you do ?
switch oc for rendering to 3.9 and 4 for gaming or
run only at 3.9ghz ?
AMD (and proud) r7 1700 4ghz-
also (1600)
asus rog crosshairs vi hero x370-
MSI 980ti G6 1506mhz slix2 -
h110 pull - acer xb270hu 1440p -
 corsair 750D - corsair 16gb 2933
https://linustechtips.com/topic/774194-100mhz-worth-it/
Not much differnce, you will hardly notice it (Above 1.4v is pretty high anyway, especially for Ryzen).
Please quote our replys so we get a notification and can reply easily. Never cheap out on a PSU, or I will come to watch the fireworks.
PSU Tier List
My specs
PC:
CPU: Intel Core i5-6600K @4.8GHz
CPU Cooler: Noctua NH-U14S
Motherboard:  ASUS Maximus VIII Hero
GPU: Zotac AMP Extreme 1070 @ 2114Mhz
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-2400
Storage: Samsung 850 EVO-Series 500GB
Storage: Western Digital Caviar Blue 1TB
Case: Cooler Master MasterCase Pro 5
Power Supply: EVGA 750W G2
Peripherals
Keyboard: Corsair K70 LUX Browns
Mouse: Logitech G502
Headphones: Kingston HyperX Cloud Revolver
Monitor: U2713M @ 75Hz
https://linustechtips.com/topic/774194-100mhz-worth-it/#findComment-9766849
I run a 1800x on stock because I already feel it is not worth the hassle :P
Personal Desktop":
Luna, the temporary Desktop:
https://linustechtips.com/topic/774194-100mhz-worth-it/#findComment-9766852
a 1800x is 4 ghz stock tho isnt it lol ?
also (1600)
https://linustechtips.com/topic/774194-100mhz-worth-it/#findComment-9766856
Seems high voltage, my 1700 is running 3.9ghz right now at 1.31V
Ryzen Ram Guide
My Project Logs   Iced Blood    Temporal Snow    Temporal Snow Ryzen Refresh
CPU - Ryzen 1700 @ 4Ghz  Motherboard - Gigabyte AX370 Aorus Gaming 5   Ram - 16Gb GSkill Trident Z RGB 3200  GPU - Palit 1080GTX Gamerock Premium  Storage - Samsung XP941 256GB, Crucial MX300 525GB, Seagate Barracuda 1TB   PSU - Fractal Design Newton R3 1000W  Case - INWIN 303 White Display - Asus PG278Q Gsync 144hz 1440P
https://linustechtips.com/topic/774194-100mhz-worth-it/#findComment-9766889
i crash at 4 ghz at 1.4  iv not tried 3.9 on a lower voltage to be honest it could be worth a shot
also (1600)
https://linustechtips.com/topic/774194-100mhz-worth-it/#findComment-9766899
Did it happen more than once at 4.0? What I mean is, can you say that it systematically fails at 4.0, and systematically works at 3.9?
The one-core turbo is. The base clock for all 8 cores is 3.6GHz. You are running 8 cores at 4.0GHz (or 3.9GHz).
https://linustechtips.com/topic/774194-100mhz-worth-it/#findComment-9766960
Testin 3.9 at 1.39v now with Aida 64
so far so good
what do you think would be a good voltage for that speed
i doubt il get as low as you
also (1600)
https://linustechtips.com/topic/774194-100mhz-worth-it/#findComment-9767024
so far so good
You gotta bring it down real slowly. I know guys who tweak voltage like .015 voltz at a time.
https://linustechtips.com/topic/774194-100mhz-worth-it/#findComment-9767054
How long to validate stability before I bring it down ?
also (1600)
https://linustechtips.com/topic/774194-100mhz-worth-it/#findComment-9767077
so far so good
This is part of your problem.  AIDA64 is not the best load to determine stability, especially if you are working with videos now.
RealBench would be a far better stress test for determining stability for these types of loads.  Be prepared for the fact that you will have to raise voltage a bit in order to pass any extended testing with RealBench.  AIDA64 usually only requires a little additional voltage over that require to load Windows, which should tell you something.
RealBench also loads your GPUs at the same time.  You know, typical loads you might experience with rendering.  :D
The best thing to do is to test your stability with several different tests and not just one.
https://linustechtips.com/topic/774194-100mhz-worth-it/#findComment-9767727
