Is This RAID Card Water Damaged?
Solved by Windows7ge,
I see the marks primary around the through hole components. It may be old dried flux residue from hand soldering. I've also seen this on old equipment. Sometimes I think it's sticky adhesive that simply collected very fine particle dust. Try rubbing it off with your finger or nail. You can also try rubbing alcohol and a Q-tip. Mineral deposits from water don't come off easy (I work part time as a janitor. Cleaning hard water deposits suck). If it comes off relatively easily then I doubt it's from water.
