ok so i have an asus crosshair6 hero i have the latest bios update (1002). i am unable to monitor cpu temps thru, ai suit 3, nzxt cam, or ryzen master. i can see mobo, gpu and vrams temp perfectly but no cpu temps as if the cpu was at freezing temperatures ( 0C, 32F). ive tried to do some research i but cant seem to find a solid find that would clearly say how to fix this little problem. i sure i wouldn't have any problems considering that my cpu and gpus are water cooled but it would be nice to know every temp. i could get one of those thermometer g1/4 plugs for my res but that would be during desperate times. so if anyone knows of a way i could fix my little issue please do not hesitate on giving me any possible solutions.  thanks
https://linustechtips.com/topic/769674-no-ryzen-cpu-temps/
HWMonitor or CPU-Z?
Builds:
https://linustechtips.com/topic/769674-no-ryzen-cpu-temps/#findComment-9716293
2 minutes ago, venomzeo said:
just downloaded it. still nothing. its not reading temps. before i started to do any research, i went to bios to make sure that the monitor was even on and it is enabled. i dont know what else to
That is very strange... Researching problems like this now.
GPU: XFX RX 7900 XTX
CPU: Ryzen 7 7800X3D
https://linustechtips.com/topic/769674-no-ryzen-cpu-temps/#findComment-9716326
Eh? That is odd, could we see a screenshot of HW Monitor?
https://linustechtips.com/topic/769674-no-ryzen-cpu-temps/#findComment-9716361
@venomzeo Crosshair user here. 1st of all 1002 is not the latest bios, they take awhile to reach the product support page.
https://rog.asus.com/forum/showthread.php?91766-Crosshair-VI-Hero-UEFI-build-0079-0081-0082-0083
Get 0082 from here it contains the latest AMD AGESA micro code.
Monitor temps in ryzen master it is most accurate. Failing that Hwinfo64 is great and updated for Ryzen. I've had issues with HW monitor reporting incorrect voltage.
Lastly if all of the above fails go in the bios -> tweakers paradise -> sensemi skew -> disabled.
EDIT: HWinfo64
https://www.fosshub.com/HWiNFO.html/hw64_550.zip
https://linustechtips.com/topic/769674-no-ryzen-cpu-temps/#findComment-9716389
ill keep tat in mind. updating bios right now. brb
https://linustechtips.com/topic/769674-no-ryzen-cpu-temps/#findComment-9716452
3 minutes ago, venomzeo said:
ok well i didnt update the bios yet cus i saw it was still a test update so i honestly didnt want to take a chance but i went along and dsiabled sense MI any ways and still nothing.
Strange...Does ryzen master or hwinfo give anything?
Btw yes its a beta bios but its provided by asus staff so dw. im using 0082 its a lot better than 1002 for stability as it has an AMD microcode update. I've used all bios revisions since launch.
https://linustechtips.com/topic/769674-no-ryzen-cpu-temps/#findComment-9716547
nothing
https://linustechtips.com/topic/769674-no-ryzen-cpu-temps/#findComment-9716557
