1 minute ago, Saif-_-Help said:
Hi.
i need some help, I'm planing on getting 3x ultrawide monitors (100hz) and i wanna know is possible to run them on sli gtx 980ti 1450mhz? And is there any games or programs that support that resolution?
Depends on what ultrawides you get. 1440p or 1080p?
the question is, how much of a neck injury are you gonna get from turning your head back and forth all day.
as for my actual answer to your question, that'll probably be a yes, but also adding that you absolutely shouldnt ever do that.
May I ask why?
SLI 980Ti might struggle a bit with triple 1440P monitors. you'd be better off getting a single 4K ultrawide. best gaming experience imo!
Yeah but good luck EVER reaching that 100 FPS thresh hold on any game...  one 1440p ultrawide taxes a gtx 1070 and runs well on a 1080, for 3 you'd need (*guesstimate here folks*) 2*1080 ti
Want to custom loop?  Ask me more if you are curious
Holy fudge that's 3k worth of monitors...
More than all the electronics I own combined ;_;
Make sure to quote me or tag me when responding to me, or I might not know you replied! Examples:
Do this:
Quote
And make sure you do it by hitting the quote button at the bottom left of my post, and not the one inside the editor!
Or this:
@DocSwag
Buy whatever product is best for you, not what product is "best" for the market.
Interested in computer architecture? Still in middle or high school? P.M. me!
I love computer hardware and feel free to ask me anything about that (or phones). I especially like SSDs. But please do not ask me anything about Networking, programming, command line stuff, or any relatively hard software stuff. I know next to nothing about that.
Compooters:
Desktop:
CPU: i7 6700k, CPU Cooler: be quiet! Dark Rock Pro 3, Motherboard: MSI Z170a KRAIT GAMING, RAM: G.Skill Ripjaws 4 Series 4x4gb DDR4-2666 MHz, Storage: SanDisk SSD Plus 240gb + OCZ Vertex 180 480 GB + Western Digital Caviar Blue 1 TB 7200 RPM, Video Card: EVGA GTX 970 SSC, Case: Fractal Design Define S, Power Supply: Seasonic Focus+ Gold 650w Yay, Keyboard: Logitech G710+, Mouse: Logitech G502 Proteus Spectrum, Headphones: B&O H9i, Monitor: LG 29um67 (2560x1080 75hz freesync)
Home Server:
CPU: Pentium G4400, CPU Cooler: Stock, Motherboard: MSI h110l Pro Mini AC, RAM: Hyper X Fury DDR4 1x8gb 2133 MHz, Storage: PNY CS1311 120gb SSD + two Segate 4tb HDDs in RAID 1, Video Card: Does Intel Integrated Graphics count?, Case: Fractal Design Node 304, Power Supply: Seasonic 360w 80+ Gold, Keyboard+Mouse+Monitor: Does it matter?
Laptop (I use it for school):
Surface book 2 13" with an i7 8650u, 8gb RAM, 256 GB storage, and a GTX 1050
And if you're curious (or a stalker) I have a Just Black Pixel 2 XL 64gb
lol, this is 1440p ultrawide.  its closer to 4k (1440p*3550 or so)
yeah but i mean ultrawide 4K. triple UW1440P is pretty heavy stuff, even when you're doing SLI on pretty high end cards..
4K ultrawides don't exist :P
Also 980 ti is basically a gtx 1070 and if you add perf degradation via sli you'd be capable of comfortably pushing 60 fps on two of those monitors at mid-high settings.  add a third and your fps and quality take a nose dive.
i thought UW4k was the term for 3840x1600 monitors?
Still not quite industry standard (or marketing standard) 4K.  I actually kinda despise the "2k, 3k, 4k, 5k 8k" whatever, it just muddies the water so much that it becomes irrelevant.
Also, only one UW4k monitor is available to the  consumer and it costs $1500 with a refresh rate of 75Hz
Personally I would consider a 38" 3840x1600 (LG and ACER both have one) instead since your option would be too wide to be comfortable.
Or, if you really want triple monitors, do a 21:9 in the middle with two 16:9 monitors on the side.
That's what I would consider them as well. Many people don't realize they exist yet (to be fair there are only two out that I know of).
Primary PC-
CPU: Intel i7-6800k @ 4.2-4.4Ghz   CPU COOLER: Bequiet Dark Rock Pro 4   MOBO: MSI X99A SLI Plus   RAM: 32GB Corsair Vengeance LPX quad-channel DDR4-2800  GPU: EVGA GTX 1080 SC2 iCX   PSU: Corsair RM1000i   CASE: Corsair 750D Obsidian   SSDs: 500GB Samsung 960 Evo + 256GB Samsung 850 Pro   HDDs: Toshiba 3TB + Seagate 1TB   Monitors: Acer Predator XB271HUC 27" 2560x1440 (165Hz G-Sync)  +  LG 29UM57 29" 2560x1080   OS: Windows 10 Pro
Album
Other Systems:
Home HTPC/NAS-
CPU: AMD FX-8320 @ 4.4Ghz  MOBO: Gigabyte 990FXA-UD3   RAM: 16GB dual-channel DDR3-1600  GPU: Gigabyte GTX 760 OC   PSU: Rosewill 750W   CASE: Antec Gaming One   SSD: 120GB PNY CS1311   HDDs: WD Red 3TB + WD 320GB   Monitor: Samsung SyncMaster 2693HM 26" 1920x1200 -or- Steam Link to Vizio M43C1 43" 4K TV  OS: Windows 10 Pro
Offsite NAS/VM Server-
CPU: 2x Xeon E5645 (12-core)  Model: Dell PowerEdge T610  RAM: 16GB DDR3-1333  PSUs: 2x 570W  SSDs: 8GB Kingston Boot FD + 32GB Sandisk Cache SSD   HDDs: WD Red 4TB + Seagate 2TB + Seagate 320GB   OS: FreeNAS 11+
Laptop-
CPU: Intel i7-3520M   Model: Dell Latitude E6530   RAM: 8GB dual-channel DDR3-1600  GPU: Nvidia NVS 5200M   SSD: 240GB TeamGroup L5   HDD: WD Black 320GB   Monitor: Samsung SyncMaster 2693HM 26" 1920x1200   OS: Windows 10 Pro
Having issues with a Corsair AIO? Possible fix here:
Are you getting weird fan behavior, speed fluctuations, and/or other issues with Link?
Are you running AIDA64, HWinfo, CAM, or HWmonitor? (ASUS suite & other monitoring software often have the same issue.)
Corsair Link has problems with some monitoring software so you may have to change some settings to get them to work smoothly.
-For AIDA64: First make sure you have the newest update installed, then, go to Preferences>Stability and make sure the "Corsair Link sensor support" box is checked and make sure the "Asetek LC sensor support" box is UNchecked.
-For HWinfo: manually disable all monitoring of the AIO sensors/components.
-For others: Disable any monitoring of Corsair AIO sensors.
That should fix the fan issue for some Corsair AIOs (H80i GT/v2, H110i GTX/H115i, H100i GTX and others made by Asetek). The problem is bad coding in Link that fights for AIO control with other programs. You can test if this worked by setting the fan speed in Link to 100%, if it doesn't fluctuate you are set and can change the curve to whatever. If that doesn't work or you're still having other issues then you probably still have a monitoring software interfering with the AIO/Link communications, find what it is and disable it.
There are two (LG and ACER) and they're $1500 and $1300. but if he's willing to spend $3k on three 21:9, 1440p, 100hz monitors then I'm sure $1300 is relatively cheap.
Primary PC-
Album
Other Systems:
Home HTPC/NAS-
Laptop-
Just now, pyrojoe34 said:
$1500 and $1300
where did you get those prices?  Lowest I can find is 1500.
And to be fair I'm in total agreement on the wtf ness of 3 34" UW's.  I suggest OP goes into a store or buys them one at a time to try  out the size.  I mean, 2 34" UW monitors is basically 6 feet and three is 9 feet...  Thats like having the same amount of screen width as a mid-sized car is long
Actually looks like it's on sale for $1200 now.
I still can't justify it... but man do I want one...
Primary PC-
Album
Other Systems:
Home HTPC/NAS-
Laptop-
:( wow, wish we had Micro center in Canada, that's insane.
108" of monitor is so so so pointless. unless youre sitting like 6ft away youll have to have your head on a swivvel.
Gaming PC: • AMD Ryzen 7 3900x • 16gb Corsair Vengeance RGB Pro 3200mhz • Founders Edition 2080ti • 2x Crucial 1tb nvme ssd • NZXT H1• Logitech G915TKL • Logitech G Pro • Asus ROG XG32VQ • SteelSeries Arctis Pro Wireless
Laptop: MacBook Pro M1 512gb
