Hi everyone,
I got some old ''broken' HDD from a friend of mine and he was asking if I could maybe fix them. He has a full crate of them laying around but he gave 2 to me. Could someone give me some advise how I can repair them and if it's even possible?
It's not a problem if the data is deleted.
Photo's:
8a9d6a97-bbae-4d83-8876-e997d8c4bcec.thumb.jpg.08d6d426f741179374e7c1c85d04e149.jpgede6c158-08a1-4553-b49e-8b132f04231f.thumb.jpg.4a4e04f8d29440baeb758819239ac816.jpg
Thanks!
My own build: RΛZΞR theme
CPU: Intel Core i5 7600K // CPU cooler: Cryorig H7 // Motherboard: MSI Z270 gaming pro carbon //
Video Card: MSI Armor gtx 1070 OC 8GB // RAM: Corsair Vengeance 16GB 3200MHz //
SSD: Samsung EVO 960 500GB // HDD: 2x WD yellow edition 2TB //
Case: NZXT H440 RAZER edition // Power Supply: Corsair RM550x //
Operating Software: Windows 10 pro 64-bit
https://linustechtips.com/topic/764564-repair-hdds/
Just now, Walt said:
Hi everyone,
Photo's:
  Reveal hidden contents
Thanks!
did you check if they were really broken first? lmao
https://linustechtips.com/topic/764564-repair-hdds/#findComment-9657776
 in my experience, most external drives are a standard sata drive installed into an enclosure. I would disassemble the enclosures, remove the internal drive, and test the drive separately. Odds are, the drive is dead. If that is the case, repair wouldnt be an option as HDDs are incredibly delicate on the inside, and near impossible to repair mechanical faults. You can replace the hard drives inside and keep the enclosure though, which i would suggest doing.
******If you paste in text into your post, please click the "remove formatting" button for night theme users.******
CPU- Intel 6700k OC to 4.69 Ghz GPU- NVidia Geforce GTX 970 (MSI) RAM- 16gb DDR4 2400 SSD-2x500gb samsung 850 EVO(SATA) Raid 0 HDD- 2tb Seagate Case- H440 Red w/ custom lighting Motherboard - MSI Z170 Gaming A OS- Windows 10 Mouse- Razer Naga Epic Chroma, Final Mouse 2016 turney proKeyboard- Corsair k70 Cherry MX brown
https://linustechtips.com/topic/764564-repair-hdds/#findComment-9657803
I would use @bgibbz advice here. Then if you have more issues, you can always contact a data recovery centre like Gilware.
Mainline: MacBook Air M1 Display(s): Acer K272HUL; VIOTEK - GNV32DB Keyboard/Mouse: Logitech M720/K780 Sound: AirPods 3 Operating System: MacOS Phone: iPhone 13 Pro (Graphite)
https://linustechtips.com/topic/764564-repair-hdds/#findComment-9657812
As bgibbz said, probably just use the enclosures and scrap the drives, even if they could work they are likley to fail.
You could put an SSD in those and make a really rugged portable drive
https://linustechtips.com/topic/764564-repair-hdds/#findComment-9657818
I think it's possible to fix anything with the right knowledge and tools. The question is how long will it last before it breaks again?
I think you would need schematics. Particularly voltage rails and probe them with a multimeter to test if they're correct.
Worst case scenario the read head has ceased up and you have to replace it and any damaged platters.
https://linustechtips.com/topic/764564-repair-hdds/#findComment-9657836
If you really want to fix them, hook them up to a sata cable in a test rig and see if you can access the data that way. If you can, something in there is good. Run a chkdsk on it to see if there are errors, and if it can fix them. Then, if you want to reuse them, erase the drive/s and write zeros to them (ei don't just reformat it). Bbiz and Scratch are still correct though, are the drives worth salvaging? I couldn't see their specs so I don't know. Anything under 500 gb I wouldn't bother. (Or maybe I would, but I'm silly like that).
There is enough youth in this world, how about a fountain of smart?
https://linustechtips.com/topic/764564-repair-hdds/#findComment-9657851
do you have one of these in your house?
if not you will never be able to repair a HDD with broken internals
Case:- 4U Rack Mount Case | Cooler:- Antec Kuhler H600 | CPU:- Intel i5 4690K @ 4.50GHz GPU:- Zotac GeForce GTX 970 4GB AMP! Omega Core Edition @ 1449MHz | Motherboard:- MSI Z97S SLI Krait | PSU:- XFX XTR 650W Gold | RAM:- HyperX DDR3 1866MHz 4GB White (x2) Black (x2) | Storage:- Kingston V300 120GB | Storage 2:- Seagate FireCuda 1TB | Build Log |
https://linustechtips.com/topic/764564-repair-hdds/#findComment-9657910
EYYY! DiY Perks!
https://linustechtips.com/topic/764564-repair-hdds/#findComment-9657917
