Ethernet problems
TheWildLamb
23 minutes ago, paddy-stone said:
Try another cable, at the moment you have tested 2 devices with that same cable/port and they both test out at 100Mbps, so trying another cable and/or port on the router with both devices would narrow down the problem for us maybe, or at least make us look elsewhere... I suspect that the cable may not be cat5e, or that the port you are using is only 10/100 rated, check the router to see what it says, also could you post here what make and model router you have please? also, might be a good idea to get another cable if you don't have one.
At least we definitely know it's not anything ISP side of the equation and that you are getting the speeds you pay for, just that something in your equipment is not up to spec or has wrong settings applied, or both.
please get back to use with the info above.
i tried a new cable which just stopped my internet so i plugged the previous wire and it has given me a very shaky connection (keeps connecting and disconnecting)
did you ever check the router info etc I asked you about ?
Please quote my post, or put @paddy-stone if you want me to respond to you.
  • PCs:-
  • Main PC build  https://uk.pcpartpicker.com/list/2K6Q7X
  • ASUS x53e  - i7 2670QM / Sony BD writer x8 / Win 10, Elemetary OS, Ubuntu/ Samsung 830 SSD
  • Lenovo G50 - 8Gb RAM - Samsung 860 Evo 250GB SSD - DVD writer
  • Displays:-
  • Philips 55 OLED 754 model
  • Panasonic 55" 4k TV
  • LG 29" Ultrawide
  • Philips 24" 1080p monitor as backup
  • Storage/NAS/Servers:-
  • ESXI/test build  https://uk.pcpartpicker.com/list/4wyR9G
  • Main Server https://uk.pcpartpicker.com/list/3Qftyk
  • Backup server - HP Proliant Gen 8 4 bay NAS running FreeNAS ZFS striped 3x3TiB WD reds
  • HP ProLiant G6 Server SE316M1 Twin Hex Core Intel Xeon E5645 2.40GHz 48GB RAM
  • Gaming/Tablets etc:-
  • Xbox One S 500GB + 2TB HDD
  • PS4
  • Nvidia Shield TV
  • Xiaomi/Pocafone F2 pro 8GB/256GB
  • Xiaomi Redmi Note 4
  • Unused Hardware currently :-
  • 4670K MSI mobo 16GB ram
  • i7 6700K  b250 mobo
  • Zotac GTX 1060 6GB Amp! edition
  • Zotac GTX 1050 mini
its the bt home hub 5. thats all i know about it, where can i find more info about it?
Ahh shit, I hate those things. I have one myself, and don't use it as it will not let some things work properly and have a better router anyway. I know several people that have had similar problems, changing to a better router solved the problem straight away. I suspect it might be a firewall problem on the HH5... but don't know for sure. All I know is in my own case I was glad I already have a decent router to use instead.
I would suggest to you about buying a router, but that's a big outlay and may not be your problem, considering that you had the connection working fine before you re-installed windows right? You didn't try to change stuff on your router too did you?
The most logical thing would be your adaptor being the problem, did you try disabling it and making a new connection as I said in a previous post?
  • PCs:-
  • Displays:-
  • LG 29" Ultrawide
  • PS4
  • Nvidia Shield TV
