How many GB memory does Ryzen 1800X Maximum support?
It supports up to 4 memory sticks , and the biggest memory sticks you can buy these days are 16 GB, so that means you can use 4 x 16 = 64 GB of memory.
The processors support ECC memory (unbuffered, unregistered), AMD doesn't actively disable it, they just don't validate particular memory sticks as they would validate on server platforms.
So if you put ECC memory sticks the processor will use the ECC functionality. (provided the motherboard BIOS doesn't set the ECC to disabled by default and hide the BIOS option)
// In theory, 64bit processors can access up to 2 ^ 64 bits of memory, but to make processors simpler and faster (less transistors), the current processors use only 48 bits (the first 64bit processors were limited to 40bit).
So basically pretty much all 64 bit processors these days have a virtual address space of 2^48 = 281,474,976,710,656 bytes of memory, which is equal to 256 TB of memory. There just aren't motherboards with enough memory slots and memory sticks with big enough memory chips to reach that size.
As far as I'm aware, the biggest size memory chips available in volume are 8 Gbit (1 GB), so ram manufacturers use 8 or 16 such chips to make 8 GB or 16 GB memory sticks.
