Yeah you need some sort of program to check it. There are many good ones including, but not limited to: MSI Afterburner, CPU-Z and NZXT Cam. These are ones I have experience with and can say they are good.
https://linustechtips.com/topic/748928-cpu-temperature/#findComment-9482403
3 minutes ago, L3x0 said:
Does anyone know how I can check my CPU temperature? Do I have to download anything?
I use HWMonitor.
[FS][US] Corsair H115i 280mm AIO-AMD $60+shipping
System specs:
Asus Prime X370 Pro - Custom EKWB CPU/GPU 2x360 1x240 soft loop - Ryzen 1700X - Corsair Vengeance RGB 2x16GB - Plextor 512 NVMe + 2TB SU800 - EVGA GTX1080ti - LianLi PC11 Dynamic
https://linustechtips.com/topic/748928-cpu-temperature/#findComment-9482413
21 minutes ago, deXxterlab97 said:
MSI Afterburner
CPU-Z
Aida64
Open Hardware Monitor
HWinfo64
CoreTemp
Speedfan
AMD Over drive for all you 6 fx users.
                     ¸„»°'´¸„»°'´ Vorticalbox `'°«„¸`'°«„¸
`'°«„¸¸„»°'´¸„»°'´`'°«„¸Scientia Potentia est  ¸„»°'´`'°«„¸`'°«„¸¸„»°'´
https://linustechtips.com/topic/748928-cpu-temperature/#findComment-9482525
Hwmonitor seems like the best to me.
NZXT CAM is a bit messed up and just feels slow.
Intel i7 12700K | Gigabyte Z690 Gaming X DDR4 | Pure Loop 240mm | G.Skill 3200MHz 32GB CL14 | CM V850 G2 | RTX 3070 Phoenix | Lian Li O11 Air mini
Samsung EVO 960 M.2 250GB | Samsung EVO 860 PRO 512GB | 4x Be Quiet! Silent Wings 140mm fans
WD My Cloud 4TB
https://linustechtips.com/topic/748928-cpu-temperature/#findComment-9482545
I use HWMonitor, because it does all the hardware in your computer (has a lot of extra readings as well in case you care like fan speeds and voltages)
https://linustechtips.com/topic/748928-cpu-temperature/#findComment-9482552
2 minutes ago, DoctorZeus said:
6? Did they have a sale recently?
well I'm 1 and I've seen a few people asking about overclocking them. 6 seemed like a good number to go with.
on the note of overdrive it doesn't actually tell you the temp but the amount left until throttling e.g if it says 52c there is 52c between current temp and its tcase.
https://linustechtips.com/topic/748928-cpu-temperature/#findComment-9482561
