Bought a 1080ti - should I upgrade my 1080p monitor?
Solved by Mr.Meerkat,
4 minutes ago, Nick The Belgian Guy said:Yeh I absolutely love the 144hz refresh and don't think I can turn back after having it.
You have any recommendations for a IPS 1440p 144Hz monitor?
Acer Predator XB271HU
165Hz refresh rate, 1440p, g sync, IPS ect. albeit it is expensive...
I guess googling "1440p 144Hz IPS" should yield you some results
