Desktop Will Not Connect to Ethernet(See Info-graphic)
8 minutes ago, FAQBytes said:I had a hunch about that too, but again, it seems like a stretch. I had it up and running for several months on the same network, but it stopped working when switching buildings. It never actually connected in this building, which seems to invalidate that theory. I've just done workarounds for the time being when making minor changes. I'm planning on changing GPUs in the near future, so having it direct wired would be so much easier and faster. I'll find a workaround eventually, but I was mostly just looking for suggestions.
Well, different building would have a different network switch. Different switch could be running a different configuration. One the server doesn't like. You can try using a cheap 1Gbit switch and using it in line. I have heard though that some managed switches can detect if an end device is plugged into a specific port or another switch. If this is the case a switch won't work. A security vulnerability in this case though is that you can get around it using a hub. Hub's aren't intelligent, switches are. On a small enough network a hub would work fine. Some things worth testing if you can. It might give you the direct connection you desire. Plus if the switch works you can run your laptop on the Ethernet. Have faster pings.
