Best air cooler?
Go to solution Solved by TheSLSAMG,
Dark Rock Pro 2
Dark Rock Pro 2
https://linustechtips.com/topic/71430-best-air-cooler/#findComment-978504
Thanks, thought that might be the case.
What's the difference between the Dark Rock, and the Dark Rock Pro?
The Pro 2 is dual tower, while the non-Pro has 1 tower.
https://linustechtips.com/topic/71430-best-air-cooler/#findComment-978522
Phanteks PH-TC14PE or Thermalright Silver Arrow SB-E
https://linustechtips.com/topic/71430-best-air-cooler/#findComment-978529
NH-D14, there may be some coolers which work a tiny bit better but noctuas build quality, noise levels and performance are very very good
CPU: i5 4670k with Noctua C12P-SE14 GPU: Gigabyte GTX 770 SSD: 250gb Samsung EVO MOBO: MSI Z87-G43 RAM: 8GB G-Skill 1600mhz PSU: Antec HCG 620W CASE: Corsair 300R windowed
https://linustechtips.com/topic/71430-best-air-cooler/#findComment-978566
i'm sporting a Prolimatech Megahalems Black Edition and it is not as big as the D14
and TC14PE, but a compact efficient cooler without monster weight.
with this kinda look (not my build) on Haswell 4770k:
https://linustechtips.com/topic/71430-best-air-cooler/#findComment-978826
Cooler Master V8 GTS
cebit_2013_uj_hutesi_megoldasokkal_jelen
-The Bellerophon- Obsidian 550D-i5-3570k@4.5Ghz -Asus Sabertooth Z77-16GB Corsair Dominator Platinum 1866Mhz-x2 EVGA GTX 760 Dual FTW 4GB-Creative Sound Blaster XF-i Titanium-OCZ Vertex Plus 120GB-Seagate Barracuda 2TB- https://linustechtips.com/main/topic/60154-the-not-really-a-build-log-build-log/ Twofold http://linustechtips.com/main/topic/121043-twofold-a-dual-itx-system/ How great is EVGA? http://linustechtips.com/main/topic/110662-evga-how-great-are-they/#entry1478299
https://linustechtips.com/topic/71430-best-air-cooler/#findComment-978852
Phanteks PH-TC14PE, Alpenföhn K2 Mount Doom, Prolimatech Blue Series Armageddon, Prolimatech Black Megahalems, BeQuiet Dark Rock Pro 2.
Rig Specs:
AMD Threadripper 5990WX@4.8Ghz
Asus Zenith III Extreme
Asrock OC Formula 7970XTX Quadfire
G.Skill Ripheartout X OC 7000Mhz C28 DDR5 4X16GB
Super Flower Power Leadex 2000W Psu's X2
Harrynowl's 775/771 OC and mod guide: http://linustechtips.com/main/topic/232325-lga775-core2duo-core2quad-overclocking-guide/ http://linustechtips.com/main/topic/365998-mod-lga771-to-lga775-cpu-modification-tutorial/
ProKoN haswell/DC OC guide: http://linustechtips.com/main/topic/41234-intel-haswell-4670k-4770k-overclocking-guide/
"desperate for just a bit more money to watercool, the titan x would be thankful" Carter -2016
https://linustechtips.com/topic/71430-best-air-cooler/#findComment-981516
Dark Rock Pro 2
Gaming System: i7 3770k @4.6GHz, Gigabyte Z77X-UD5H, 8GB Corsair 1600MHz, 2 x MSI GTX 670 PE, Fractal R4, 256GB Crucial M4, Fractal Newton R3 1000W White
Steam Box: Xeon E3 1280 @ 3.5GHz, Intel S1200KP, 8GB Corsair White LP, 1x EVGA GTX 570, Fractal Node 304 White, 64GB Intel SSD, Fractal Tesla R2 650w White
https://linustechtips.com/topic/71430-best-air-cooler/#findComment-981968
Cooler master 212 Evo!
+1
Wanna hang out with me and people like @Theslsamg, @ Ssoele, @BENTHEREN, @Lanoi, @Whiskers, @_ASSASSIN_, @Looney, @WunderWuffle, and @nsyedhasan. Well.... Check out: http://linustechtips.com/main/topic/48484-unofficial-linustechtips-teamschnitzel-server-teamspeak/
https://linustechtips.com/topic/71430-best-air-cooler/#findComment-988506
Noctua has some great coolers!
Intel i5 6600k~Asus Maximus VIII Hero~G.Skill Ripjaws 4 Series 8GB DDR4-3200 CL-16~Sapphire Radeon R9 Fury Tri-X~Phanteks Enthoo Pro M~Sandisk Extreme Pro 480GB~SeaSonic Snow Silent 750~BenQ XL2730Z QHD 144Hz FreeSync~Cooler Master Seidon 240M~Varmilo VA87M (Cherry MX Brown)~Corsair Vengeance M95~Oppo PM-3~Windows 10 Pro~http://pcpartpicker.com/p/ynmBnQ
https://linustechtips.com/topic/71430-best-air-cooler/#findComment-988809
While I appreciate the replies, it says answered for a reason ;)
You my friend opened Pandora's Box on this one....1. Xigmatek DK2  2. Prolimatech Megahalems Black Edition 3.Dark Rock and DR Pro 2....this is the kind of question like.."Who do you like better AMD or Nvidia/Intel.... ;)
Case: Silverstone SG09B Motherboard: MSI Z10 Morter M-ATX CPU: I5-6600K  Ram: Corsair LP 2400 DD4 16GB GPU: MSI RX 480 Storage: Seagate HDD Baracuda 2TB x2, Crucial M200 500GB SSD X2 (Raid 0)PSU: Silverstone Strider Gold 1000W w/PP05E Kit
"When to say :blink: WTF :blink: ....$2K rig only used for Minesweeper and Internet Checkers marathons...."
https://linustechtips.com/topic/71430-best-air-cooler/#findComment-992483
