1 minute ago, deXxterlab97 said:
Pascal? python? c? java? visual basic?
Python is a good scripting langue, learn it.
Pascal, meh no
C, why not C++ or objective C.
Java, Learn it
not a huge windows guy so no visual basic here.
https://linustechtips.com/topic/712782-need-help/#findComment-9093153
2 hours ago, Electronics Wizardy said:
Meh start with c++, argue with me guys.
Batch programming is best...
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
https://linustechtips.com/topic/712782-need-help/#findComment-9093566
3 hours ago, IHirs said:
probably create video games
That's a very long and highly competitive road that yields limited financial rewards unless you (think you) are something special or are particularly driven towards this end.
or usefull applications
Well it would be rather strange if you were aspiring to create useless applications now wouldn't it... Since the general purpose of an application is to provide a solution to some kind of problem.
The single biggest problem in communication is the illusion that it has taken place.
https://linustechtips.com/topic/712782-need-help/#findComment-9093667
Some may disagree with me here, but I would also urge you not to think that you absolutely have to use a "modern" language. As an engineer at a company with some very large datasets, I still occasionally write programs in Fortran, because it's fast. Do I suggest starting with it? Probably not... these day's you can't make "fun" applications out of Fortran as easily as you can with say, Python. And you probably don't have a processor so slow python will chew it up.
I personally find Python the easiest to program in, but I'm not sure if that's because I have previous experience in programming, or it's actually the easiest for me. I find it's syntax to be very simple and intuitive, and the most "human readable", though I suppose a lot of people would argue that point.
Java is a great one if you want to have skills that will get you hired at many larger companies - though it differs by company, many large companies depend on Java - mine included - and seek primarily Java developers who have skills in other languages second (like Fortran). Plus you don't have to worry about your code not porting to other operating systems... simple things like sending terminal based commands will break if you port a python script from windows to Linux.
https://linustechtips.com/topic/712782-need-help/#findComment-9094443
