Best 8GB DDR4 21333Mhz 288pin SDRAM
Solved by iRileyx,
Just now, sna2295 said:Thanks mate..
I'll now put forward a query to asus technical team with the screenshot of their official website where its mentioned SO-DIMM and ask why a 288-pin DDR4 SDRAM has been suggested to me till now.
Yeah, should probably mention it to them cause someone got it wrong somewhere, but from the looks of it, he got it mixed up and told you the wrong info for it.
Featured Topics
sgreenberg ·
Posted in Networking0 -
1
VinSen ·
Posted in Troubleshooting5 -
1
LLENNxP90 ·
Posted in CPUs, Motherboards, and Memory1 -
4
1
Gat Pelsinger ·
Posted in Laptops and Pre-Built Systems1 -
Mumintroll ·
Posted in Windows3
play_circle_filled
Latest From Tech Quickie:
Ethernet Is Named After Something Really Dumb (and other tech stories)
