if you make it straight again it will work
Builds:
https://linustechtips.com/topic/697694-shit-bent-a-cpu-pin/#findComment-8928306
it it fits it sits , just put it in the soket and it it goes in w/ not much problems it will be fine
RyzenAir : AMD R5 3600 | AsRock AB350M Pro4 | 32gb Aegis DDR4 3000 | GTX 1070 FE | Fractal Design Node 804
RyzenITX : Ryzen 7 1700 | GA-AB350N-Gaming WIFI | 16gb DDR4 2666 | GTX 1060 | Cougar QBX
PSU Tier list
https://linustechtips.com/topic/697694-shit-bent-a-cpu-pin/#findComment-8928311
Just try to get it as straight as possible, its not like your can break it more.
Please quote our replys so we get a notification and can reply easily. Never cheap out on a PSU, or I will come to watch the fireworks.
PSU Tier List
My specs
PC:
CPU: Intel Core i5-6600K @4.8GHz
CPU Cooler: Noctua NH-U14S
Motherboard:  ASUS Maximus VIII Hero
GPU: Zotac AMP Extreme 1070 @ 2114Mhz
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-2400
Storage: Samsung 850 EVO-Series 500GB
Storage: Western Digital Caviar Blue 1TB
Case: Cooler Master MasterCase Pro 5
Power Supply: EVGA 750W G2
Peripherals
Keyboard: Corsair K70 LUX Browns
Mouse: Logitech G502
Headphones: Kingston HyperX Cloud Revolver
Monitor: U2713M @ 75Hz
https://linustechtips.com/topic/697694-shit-bent-a-cpu-pin/#findComment-8928318
It's not a good idea to remove the CPU after installation unless you're upgrading. As long as the pins are straight enough, it should be okay as some are ground or unused pins.
If the pin was for power, you're f#cked! /s
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
https://linustechtips.com/topic/697694-shit-bent-a-cpu-pin/#findComment-8928436
Last time I had to remove it was when I RMA's a motherboard
Breaking things 1 day at a time
https://linustechtips.com/topic/697694-shit-bent-a-cpu-pin/#findComment-8928443
That would explain it. You should be fine. Just be conservative if it's a K-series or AMD CPU.
https://linustechtips.com/topic/697694-shit-bent-a-cpu-pin/#findComment-8928452
you can use something like a wooden ruler (i say wooden because those bend the least, compared to plastic ones that are kinda flexy) if you have one that's thin enough to gently bend it back in "line" with all the other pins, but as long as it goes into the socket it's fine.
https://linustechtips.com/topic/697694-shit-bent-a-cpu-pin/#findComment-8928603
