How would I fight a DoS or DDoS attack?
Solved by Van Diekon,
10 minutes ago, schizznick said:Blocking or mitigating a DOS or DDOS attack is very difficult from a consumer grade internet connection. You need to be able to re-route packets destined for your connection prior to them heading to your connection. Even if you blocked the IP's on your server, you would still have the traffic hitting your internet connection and still causing the issue. As was suggested either hosting your server elsewhere where it can have DDOS protection or use a VPN service to hide your IP.
Good Luck.
Maybe I will just do that for this one service that I require.
I still need my server for a variety of other things.
Thank you for the comments everyone!
