Pretty sure this one doesn't have anything to do with Windows in this case. Couple things to try:
  • Reset the CMOS
  • Ensure all power connections are secure
    • Got another PSU lying around? Try swapping the PSU and see if there's any change.
  • Pull the GPU, all RAM, and basically everything but the power cables and the CPU+cooler. Does it stay on?
    • If yes, try adding parts back to the equation one by one
https://linustechtips.com/topic/683976-pc-wont-fully-start/#findComment-8787436
  • Reset the CMOS
No extra psu but I'll try the rest
https://linustechtips.com/topic/683976-pc-wont-fully-start/#findComment-8787457
You might also want to place the GPU in a different slot, if any are available.
You might also want to try one stick of ram, and test all slots. If none work, try the second stick in all slots. If your motherboard has onboard video, try that instead of the GPU.
https://linustechtips.com/topic/683976-pc-wont-fully-start/#findComment-8787478
  • Reset the CMOS
After resetting the cmos and testing parts, I found that one of my 4gb hyperx fury ram dimms ain't working, with it in the boot cycle continues. Rip
https://linustechtips.com/topic/683976-pc-wont-fully-start/#findComment-8787587
@Runefox @Dutch-stoner @gtx1060=value The ram seems to be working today however windows won't boot properly,  last night it would sign me into a temporary profile, and today windows won't even boot??
safe to assume windows is corrupted? :(
https://linustechtips.com/topic/683976-pc-wont-fully-start/#findComment-8792654
yes - get a new install disk
https://linustechtips.com/topic/683976-pc-wont-fully-start/#findComment-8792673
I would just download windows onto a usb and go into bios and set the boot disk to the usb - then just reinstall windows
https://linustechtips.com/topic/683976-pc-wont-fully-start/#findComment-8792905
7 minutes ago, Runefox said:
I would first run Memtest86 to be sure the RAM is actually good, and I'd check the hard drive with SeaTools for DOS afterwards to be sure it's above board, too. Then I'd go ahead with the Windows reinstall if everything checks out.
How would I run this if windows won't start?
https://linustechtips.com/topic/683976-pc-wont-fully-start/#findComment-8792947
Memtest86 can be placed onto a USB flash drive as an EFI-bootable program, while SeaTools you'd need to either burn or create a USB boot drive using Rufus or Universal USB Installer and set your BIOS to boot in Legacy mode rather than UEFI.
https://linustechtips.com/topic/683976-pc-wont-fully-start/#findComment-8792964
It's been running for an hour with no errors so seems good
https://linustechtips.com/topic/683976-pc-wont-fully-start/#findComment-8793380
