What will you use it for? Macbooks aren't really known for their value and the new ones cant really be called "Pro".
Please quote our replys so we get a notification and can reply easily. Never cheap out on a PSU, or I will come to watch the fireworks.
PSU Tier List
My specs
PC:
CPU: Intel Core i5-6600K @4.8GHz
CPU Cooler: Noctua NH-U14S
Motherboard:  ASUS Maximus VIII Hero
GPU: Zotac AMP Extreme 1070 @ 2114Mhz
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-2400
Storage: Samsung 850 EVO-Series 500GB
Storage: Western Digital Caviar Blue 1TB
Case: Cooler Master MasterCase Pro 5
Power Supply: EVGA 750W G2
Peripherals
Keyboard: Corsair K70 LUX Browns
Mouse: Logitech G502
Headphones: Kingston HyperX Cloud Revolver
Monitor: U2713M @ 75Hz
I would probably get a 2015 Macbook Pro 13" if I was going for an apple laptop, I don't like large laptops and I don't like how the 2016 Macbook pro is so limited since it only has 2 or 4 USB C ports.
If you are looking for other recomendations, I would highly recomend the HP Probook, HP Elitebook, HP Zbook, Lenovo Thinkpad and Dell Vostro and Dell Latitude series.
22 minutes ago, Merkava_mk said:
I am deciding between the new 13inch touch bar macbook pro vs the 2015 15inch refurbished macbook pro
How do you intend to use them, for what tasks?
What are the specs of the refurbished 15 inch, and which configuration of the 13 inch will you buy?
On a side note, I tend to prefer staying away from refurbished.  I don't always trust the conditions of the hardware inside, especially the battery.
That is not dead which can eternal lie.  And with strange aeons even death may die. - The Call of Cthulhu
A university is not a "safe space". If you need a safe space, leave, go home, hug your teddy & suck your thumb until ready for university.  - Richard Dawkins
What ever you choose 8Gb RAM and 256Gb storage is the minimum i would use. Mine sits on about 100Gb used drive space, thats just Xcode, android studio, a few statistics and database related programs, no media or data. Some of that could be cleaned up but its reflective of me using it. How much drive space you need unused depends on who you ask but its generally around 25%.
If you can afford a new one, get a new one. I like what they have done and my only complaint is they haven't updated their other products
ψ ︿_____︿_ψ_
Do not get an apple, You will regret it, Only get it if you are used to it and familiar with the software as well as the OS.
Current PC: "For Now Because I Have A Habit"
CPU: Intel Core I7 6700K @4.5Ghz
Motherboard: Asrock Z170 Extreme4
RAM: 16GB G.skill TridentZ 3200Mhz DDR4
CPU Cooler: Thermaltake Water 3.0 360 Riing RGB Edition
Graphics Card: Nvidia Geforce GTX 1080Ti Founders Edition MSI
Case: Limited Edition Thermaltake View 31 Riing RGB
Power Supply: CoolerMaster V750 Fully Modular
SSD: Kingston HyperX Savage 240GB
HDD: 3TB Toshiba 7200RPM
Peripherals:
Monitor: AOC U2868PQU 4K 28" 60HZ
Keyboard: G.Skill Ripjaws KM780 RGB Cherry MX Red
Mouse: Razer Deathadder Elite
Mouse Pad: Razer Goliathus Speed Extended
Speakers: Creative SBS A250
Headphones: Razer Kraken Pro 7.1
8 minutes ago, The Belgian Waffle said:
It depends on what you're planning to do with it. If it's college related, get the Air (unless you need to run some heavy 3D programs).
If you need to do some "pro" tasks, don't get a MacBook Pro :P
Some "pro" tasks run better on a macbook than other laptops for the price and theres the easy portability factor. If you are doing any kind of work Id recommend the 15' because the specs are probably better and unless your switching to USB C then its easier for you. What are you doing on the laptop>?
He who asks is stupid for 5 minutes. He who does not ask, remains stupid. -Chinese proverb.
Those who know much are aware that they know little. - Slick roasting me
AXIOM
CPU- Intel i5-6500 GPU- EVGA 1060 6GB Motherboard- Gigabyte GA-H170-D3H RAM- 8GB HyperX DDR4-2133 PSU- EVGA GQ 650w HDD- OEM 750GB Seagate Case- NZXT S340 Mouse- Logitech Gaming g402 Keyboard-  Azio MGK1 Headset- HyperX Cloud Core
Offical first poster LTT V2.0
Just now, The Belgian Waffle said:
Yes
No
Other comparable laptops for the price and style are the Dell XPS series, Lenovo Yoga series, and Asus Zenbook series
AXIOM
Didn't know you could spend 3000 dollars on a DELL without even having dedicated gpu
Mhm, and you guys are bashing Apple
AXIOM
9 minutes ago, The Belgian Waffle said:
Do I?
- Sent from MacBook Air 2015
Well, you did bash the pro.
AXIOM
there might be an other reaason you know right? like no windows or an OS that is more developer friendly in certain ways.
May the light have your back and your ISO low.
I know thats why I usually recommend it to programmers
AXIOM
if you're going to use final cut pro. get a mac. if not. go look elsewhere. no 'pro' task runs okay on a ulv duo core of the new 13in mbp.
Laptop Main
(Retired) Zbook 15: i7-6820HQ, M2000M, 32gb, 512gb SSD + 2tb HDD, 4k Dreamcolor
(Retired) Alienware 15 R3: i7-6820HK, GTX1070, 16gb, 512 SSD + 1tb HDD, 1080p
(Retired) T560: i7-6600U, HD520, 16gb, 512gb SSD, 1620p
(Retired) P650RS: i7-6820HK, 1070, 16gb, 512gb + 1tb HDD, 4k Samsung PLS
(Retired) MBP 2012 Retina: i7-3820QM, GT650M, 16gb, 512gb SSD, 1800p
I just bought the 2015 13 inch retina MacBook pro base model, and I love it. It's got amazing SSD speeds (650 read, 1300 write), feels snappy, handles final cut pro, photoshop, and eclipse no problem and has great battery life. Would definitely recommend, but go for the larger SSD.
Snorlax: i7 5820k @4.5ghz, Asus X99 Pro, 32gb Corsair Vengeance LPX 2666, Cryorig R1 Ultimate, Samsung 850 evo 500gb, Asus GTX 1080 ROG Strix, Corsair RM850x, NZXT H440, Hue+
Smallsnor: Huawei Matebook X
Canon AE-1 w/ 50mm f/1.8 lens
Pentax KM w/ 55mm f/1.8 SMC lens
Zenit-E w/ 58mm f/2 Helios lens
Panasonic G7 with 14-42mm f/3.5 lens
Polaroid Spectra System
