i7 4790k Stock clocks running hot
Solved by stealth80,
Core i 2nd, 3rd and 4th Generation CPU's have AVX (Advanced Vector Extension) instruction sets. Recent versions of Prime95 run AVX code on the Floating Point Unit (FPU) math coprocessor, which produces unrealistically high temperatures. The FPU test in the software utility AIDA64 shows the same results.
Prime95 v26.6 produces temperatures on 3rd and 4th Generation processors more consistent with 2nd Generation, which also have AVX instructions, but do not suffer from thermal extremes due to having a soldered Integrated Heat Spreader and a 35% larger Die.
Please run only Small FFT’s for 10 minutes.
Your Core temperatures will test 10 to 20C lower.
Got this from Toms Hardware
Apparently you should use v26.6
