Hey guy!
I am buying i7 6700k i am on tight budget right now i dont know anything about overclocking and i dnt wana overclock it for like next 1 year So i decided to not to use stock cooler and since i am on tight budget i can afford corsair h45 liquid cooler is it ok? Will it cool my i7?
https://linustechtips.com/topic/679899-cpu-cooler/
1 minute ago, Tbags said:
Hey guy!
Eh... it will... but I prefer air cooling. Just a personal thing. Also: Unlocked processors don't come with stock coolers.
Skyggeis Specs:
CPU: Intel Core i7-6700K 4.0GHz Quad-Core Processor
CPU Cooler: CRYORIG H5 Ultimate 76.0 CFM CPU Cooler
Motherboard: MSI Z170A SLI PLUS ATX LGA1151 Motherboard
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-3000
Storage: Samsung 850 EVO 250GB 2.5" Solid State Drive
Storage: Western Digital Caviar Blue 1TB 3.5" Hard Drive
Video Card: Zotac GeForce GTX 1070 8GB AMP! Extreme
Case: Phanteks ECLIPSE P400S ATX Mid Tower Case Satin Black
PSU: Corsair RMx 750W 80+ Gold Certified Fully-Modular PSU
WiFi Card: Gigabyte GC-WB867D-I REV 4.2
Case Fan: Aerocool DS 140mm Black 93.4 CFM
Other: Coolermaster VGA Holder
Other: Phanteks LED Strip 1M
Other: Phanteks Fan Splitter
Monitor: Dell S2716DG
https://linustechtips.com/topic/679899-cpu-cooler/#findComment-8744895
It will work, but high end air will perform better for the same price (Quieter too).
Please quote our replys so we get a notification and can reply easily. Never cheap out on a PSU, or I will come to watch the fireworks.
PSU Tier List
My specs
PC:
CPU: Intel Core i5-6600K @4.8GHz
CPU Cooler: Noctua NH-U14S
Motherboard:  ASUS Maximus VIII Hero
GPU: Zotac AMP Extreme 1070 @ 2114Mhz
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-2400
Storage: Samsung 850 EVO-Series 500GB
Case: Cooler Master MasterCase Pro 5
Power Supply: EVGA 750W G2
Peripherals
Keyboard: Corsair K70 LUX Browns
Mouse: Logitech G502
Headphones: Kingston HyperX Cloud Revolver
Monitor: U2713M @ 75Hz
https://linustechtips.com/topic/679899-cpu-cooler/#findComment-8744899
3 minutes ago, Tbags said:
Hey guy!
how much is the h45?
https://linustechtips.com/topic/679899-cpu-cooler/#findComment-8744907
Just now, elBarto said:
why whould you want a i7?
i5 are starting to bottleneck and stutter in games. Take BF1, for example.
@Tbags something like an NH-D15s would outperform it.
USEFUL LINKS:
PSU Tier List F@H stats
https://linustechtips.com/topic/679899-cpu-cooler/#findComment-8744909
BF1 is apparently having issues with code not CPU.
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
https://linustechtips.com/topic/679899-cpu-cooler/#findComment-8744962
Take a Scythe Fuma if available for you or otherwise one of the mentioned Noctua's. But the price of the Fuma is much more in your favor and is also high end aircooler trading blows with the mentioned Noctua.
Anyway those aircoolers only get beat by the high end AIO's like the NZXT Kraken x61 and Corsairs like the 110 ones. But are much better then your mentioned AIO. It will work but apart from aestethics I see no reason to take it.
Is this confirmed in the meantime? Am not really following it since I don't play it, but could be the cause of the CPU drain in multiplayer.
The object of life is not to be on the side of the majority, but to escape finding oneself in the ranks of the insane.
Basic PC parts guide
PSU Tier list
https://linustechtips.com/topic/679899-cpu-cooler/#findComment-8745013
Some reports are showing errant variables and others are showing frame-rates that are too widely spaced. Dynamic resolution is also showing issues which is annoying since this is PC and we choose our resolutions.
https://linustechtips.com/topic/679899-cpu-cooler/#findComment-8745263
The H45 would work fine but an air cooler would be less likely to fail, probably cheaper, and quieter. Can you link us to where you're shopping? What's your budget?
Why not oc for a year?
https://linustechtips.com/topic/679899-cpu-cooler/#findComment-8746279
If you're not planning to overclock and are on a tight budget, grab one of the many $10-15 downdraft coolers off of Newegg. There's a refurbished Cooler Master cooler that costs $7, but has a $7 MIR on it for the next day or so. I grabbed one just to have an extra cooler with a little more beef than the stock cooler, but that will fit literally anything, sitting around.
I enjoy buying junk and sinking more money than it's worth into it to make it less junk.
https://linustechtips.com/topic/679899-cpu-cooler/#findComment-8746618
cooler master hyper 212 evo (its a meme at this Point)
or a Arctic Freezer 7 pro 2 ,those are superb and cheap (and dont use backplate bogus)
RyzenAir : AMD R5 3600 | AsRock AB350M Pro4 | 32gb Aegis DDR4 3000 | GTX 1070 FE | Fractal Design Node 804
RyzenITX : Ryzen 7 1700 | GA-AB350N-Gaming WIFI | 16gb DDR4 2666 | GTX 1060 | Cougar QBX
PSU Tier list
https://linustechtips.com/topic/679899-cpu-cooler/#findComment-8746909
Please, please, please don't buy small AIO if you have tight budget. Only valid reasons for getting one are tight space or looks. If you just want perfomance, air coolers of same price range will outperform AIOs.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/679899-cpu-cooler/#findComment-8749238
