closed HELP! How to delete a response to post?
Solved by colonel_mortis,
4 minutes ago, Akhil S said:I just did (report). But it says on the rules of the giveaway that "All duplicate posts will be deleted before the winner is drawn" So I am just afraid that - will they delete both of my posts to the giveaway?
No, that just means that one of the posts will be removed. I will update the thread to clarify that.
Featured Topics
princessmortix ·
Posted in Troubleshooting0 -
3
2
1
2
Tbaile ·
Posted in Laptops and Pre-Built Systems2 -
2
play_circle_filled
Latest From Tech Quickie:
Ethernet Is Named After Something Really Dumb (and other tech stories)
