Monitor Overclocking
RyeIII
Have anyone tried to OC their Display?
I have BenQ RL2755HM is it possible to overclocked?
What are the pros and cons of monitor overclocking?
Ryzen  5 3600 | ASUS Strix B450i Strix | G-Skill Trident Z RGB 16gb 3200mhz
Gigabyte RTX 2070 Super OC | Samsung 970 EVO Plus 500gb | NZXT H200i | NZXT x52 | Corsair RM650x
Well you get higher refresh rate from it, so if you are using V-sync, you would get more fps. If your GPU can handle it.
I don't see any point in "overclocking" monitor from 60Hz to 75Hz ... I did that with mine and there was no difference to me.
Intel i7 12700K | Gigabyte Z690 Gaming X DDR4 | Pure Loop 240mm | G.Skill 3200MHz 32GB CL14 | CM V850 G2 | RTX 3070 Phoenix | Lian Li O11 Air mini
Samsung EVO 960 M.2 250GB | Samsung EVO 860 PRO 512GB | 4x Be Quiet! Silent Wings 140mm fans
WD My Cloud 4TB
Yea you can overclock it. I overclocked mine to 71Hz. You prob won't really notice it but it might help slightly in games like csgo. If you want to just go ahead and try it.
Unsure what power supply to pick?
Check out my HTPC build.
Quote me/others so we can help you
Comic sans is the best font
I overclocked my triple to 61! I've yet to notice...
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
pros: well higher refreshrate
cons: monitor is hotter. i run mine without cover with bare metal just so it coudl cool itself better (60hz to 89hz)
I have an Asus MX259H overclocked to 72 Hz. The difference isn't "in your face" but it is definitely noticeable when there is a lot of motion going on the screen.
 I can definitely tell the difference though - for example, in Skyrim, the game physics engine bugs out at FPS beyond 60 so I use a mod to cap it at 58 to prevent it. Sometimes the FPS capper stops working properly and when that happens, I can definitely that it's going beyond 60 FPS with perfect accuracy just by recognizing the unusual fluidity of the motion on screen even before any physics problems start happening.
CPU: Ryzen 9 3900X | Cooler: Noctua NH-D15S | MB: Gigabyte X570 Aorus Elite | RAM: G.SKILL Ripjaws V 32GB 3600MHz | GPU: EVGA RTX 3080 FTW3 Ultra | Case: Fractal Design Define R6 Blackout | SSD1: Samsung 840 Pro 256GB | SSD2: Samsung 840 EVO 500GB | HDD1: Seagate Barracuda 2TB | HDD2: Seagate Barracuda 4TB | Monitors: Dell S2716DG + Asus MX259H  | Keyboard: Ducky Shine 5 (Cherry MX Brown) | PSU: Corsair RMx 850W
I did that and there was a pretty noticeable difference. It's well worth it imo. When I drop down to 60fps I can actually tell pretty well.
First build every: Intel Core i7 4790K, Asus Z97-A/USB 3.1 motherboard, Kingston HyperX FURY 1866 2x8 16GB Kit, Gigabyte Windforce GTX 970 G1 Gaming, Corsair Obsidian 450D Black ATX Mid Tower, Samsung 850 EVO 250GB & 3TB Toshiba HDD, EVGA SuperNOVA 750W G2, Corsair H100i GTX 240mm, Gigabyte Bluetooth 4.0/Wifi Card, Logitech G700S. Running on Windows 10
Surface Pro 3: i5 4300U with 8GB of ram and 256GB SSD. Running Windows 10 Pro
