How much data throughput for Steam in Home Streaming?
Solved by Electronics Wizardy,
14 minutes ago, DeadlyPilot said:If i where to connect two machines through lan, would steam in home streaming benefit from a cat6? Would it even reach a 10gbps throughput?
Also I'm a bit confused on what hardware is optimal for in home streaming. Would streaming be CPU intensive, GPU intensive, etc...
In home streaming uses about 50mb/s max. No need for anything faster than 100mb/s lan over cat 5.
It normally uses cpu or quicksync/nvec for encoding and the standard h264 decoder.
