a question about reservoirs and fittings
Solved by Jack McCall,
All compression fittings are usually universal...there may be a few exceptions out there but I'm not sure which.
Compression fittings use a screw system from behind - you put the nut over the tube before you attach it, hook the tube onto the fitting itself, and then tighten the nut over the tube so that the tube is in between the nut and fitting.
Featured Topics
NASInitiate ·
Posted in Servers, NAS, and Home Lab0 -
220VoltsallCore ·
Posted in Storage Devices4 -
2
1
1
3
13
Blazepoint5 ·
Posted in Programs, Apps and Websites3 -
5
1
