How to properly create two gta v directory folders, one for modding and MP?
Never mind found the solution to this video:
https://www.youtube.com/watch?v=gCAuilz1nbs
starts at 4:00
1.Simply copy the original gta v folder to the same place it is in which is in the Steamapps/common directory and the copied file should be automatically re-named to Grand theft Auto V-Copy
2. Rename that copy by adding either modded or vanilla to the end of that file name, depending on which file you want to currently mod (could be the copied or un-copied one<< Grand theft Auto V folder without the -copy) Would recommend you take "-copy" after renaming it out so it would be easier to identify
3.like you said whenever you want to use that Grand theft auto V copy, Rename your current un-copied one to Grand theft Auto V Modded or Vanilla, this again depends on which folder you chose to use for mods on step #2
4.then rename your copied one to orignally "Grand theft Auto V", deleting words -copy/modded/vanilla from the copy's name, Since that is the original and actual name that steam will need to read in order to launch the game<<Again like you before said themctipers
5. If you want to switch your folders again then go to step 3 to 4 again but this time you are first changing the name of your copied one (the file you just named "Grand theft auto V" but took out -copy/modded/vanilla from before naming it that.) and so on
