You guys think it is a bad idea to use old hardware as wall art? I have a OLD server (Dual Pentium 3's and 1.75Gb of DDR1, SCSI HDD interface making it nearly impossible to find drives for). Its not the most efficient thing and the fan is screwed up so it rattles alot when in use. I think it would look ok on a wall. Just wanted your thoughts
Breaking things 1 day at a time
https://linustechtips.com/topic/634751-old-hardware-as-wall-art/
There's a super high end audio shop near me that actually has some wall art made with old hardware. There is some server hardware, and I think there's also a laptop motherboard. They also took apart a hard drive and used the read/write heads, as well as the platter. It's pretty darn spiffy looking. They mounted it on (I think) half inch plate glass, which wouldn't have been cheap, but it really does look awesome!
Hey! New SIgnature!
I'm supposedly a person on the Internet, but you'll never know if I'm human or not ;)
https://linustechtips.com/topic/634751-old-hardware-as-wall-art/#findComment-8195703
pics pls.
https://linustechtips.com/topic/634751-old-hardware-as-wall-art/#findComment-8195706
Just now, ModuleLFS said:
If I had a bunch, I'd cover the entire wall with them.
Cool
https://linustechtips.com/topic/634751-old-hardware-as-wall-art/#findComment-8195707
In my opinion, only certain components would look good hanging from a wall. CPUs (especially old ones with the pins still on the chip), HDDs (maybe), but things like motherboards would just seem out of place.
Now if you got a nice looking shelf, then things would fit a little better. You could stand a GPU up on it, arrange a bunch of hard drives.
Of course, if you covered the entire wall with motherboards, then it would look amazing, but it's really all or nothing for me.
._.
AMD A8-5500•••ASUS GTX 660•••MSI MS-7778 Mobo•••2x4GB DDR3 RAM•••CoolerMaster v550 Semi-Modular PSU•••1.5TB HDD•256GB Samsung 850 Evo SSD•••Optical Drive•••Phanteks Enthoo Pro
https://linustechtips.com/topic/634751-old-hardware-as-wall-art/#findComment-8195710
Yeah you can do some pretty neat things with pcbs after you remove the caps and such. I used to glue them into patterns on cardboard and hang them in my room.
I am a paid professional, but only when I am at work...and getting paid.
https://linustechtips.com/topic/634751-old-hardware-as-wall-art/#findComment-8195715
Well since it is a rack mount server I could just take some L brackets and put them on the wall to mount it, along with some other way to secure it
https://linustechtips.com/topic/634751-old-hardware-as-wall-art/#findComment-8195719
I disagree with the motherboard point, but that's also highly dependent on the actual motherboard. I think that the older motherboards, where there are fewer components, tend to look more interesting, because you can kind of fool yourself into thinking that you can kind of understand what's going on. Plus, it's cool to see the translucent solder mask on old boards. I don't think that any modern boards would be too interesting though.
Hey! New SIgnature!
https://linustechtips.com/topic/634751-old-hardware-as-wall-art/#findComment-8195724
That might look nice. I suppose what I'm trying to say is that having a motherboard by itself might not look too sleek, but if it had some sort of frame, then things are improving.
I'd definitely want to see a picture if you do it.
._.
https://linustechtips.com/topic/634751-old-hardware-as-wall-art/#findComment-8195729
You want pics of the server im talking about?
https://linustechtips.com/topic/634751-old-hardware-as-wall-art/#findComment-8195731
I love seeing old hardware mounted to things. :) My plan is to eventually build a coffee table or desk with a glass top and sides that have working components in and lighted up.
Use this guide to fix text problems in your postGo here and here for all your power supply needs
New Build Currently Under Construction! See here!!!! ----->
Deathwatch:[CPU I7 4790K @ 4.5GHz][RAM TEAM VULCAN 16 GB 1600][MB ASRock Z97 Anniversary][GPU XFX Radeon RX 480 8GB][STORAGE 250GB SAMSUNG EVO SSD Samsung 2TB HDD 2TB WD External Drive][COOLER Cooler Master Hyper 212 Evo][PSU Cooler Master 650M][Case Thermaltake Core V31]
Cupid:[CPU Core 2 Duo E8600 3.33GHz][RAM 3 GB DDR2][750GB Samsung 2.5" HDD/HDD Seagate 80GB SATA/Samsung 80GB IDE/WD 325GB IDE][MB Acer M1641][CASE Antec][[PSU Altec 425 Watt][GPU Radeon HD 4890 1GB][TP-Link 54MBps Wireless Card]
Carlile: [CPU 2x Pentium 3 1.4GHz][MB ASUS TR-DLS][RAM 2x 512MB DDR ECC Registered][GPU Nvidia TNT2 Pro][PSU Enermax][HDD 1 IDE 160GB, 4 SCSI 70GB][RAID CARD Dell Perc 3]
Zeonnight [CPU AMD Athlon x2 4400][GPU Sapphire Radeon 4650 1GB][RAM 2GB DDR2]
Server [CPU 2x Xeon L5630][PSU Dell Poweredge 850w][HDD 1 SATA 160GB, 3 SAS 146GB][RAID CARD Dell Perc 6i]
Kero [CPU Pentium 1 133Mhz] [GPU Cirrus Logic LCD 1MB Graphics Controller] [Ram 48MB ][HDD 1.4GB Hitachi IDE]
Mining Rig: [CPU Athlon 64 X2 4400+][GPUS 9 RX 560s, 2 RX 570][HDD 160GB something][RAM 8GBs DDR3][PSUs 1 Thermaltake 700w, 2 Delta 900w 120v Server modded]
RAINBOWS!!!
 QUOTE ME SO I CAN SEE YOUR REPLYS!!!!
https://linustechtips.com/topic/634751-old-hardware-as-wall-art/#findComment-8195739
This is what I have to work with
https://linustechtips.com/topic/634751-old-hardware-as-wall-art/#findComment-8195764
0.o gimme gimme gimme!!!!! :P  take it out of the case, mount the mobo to a blacked out board,and take the drives, paint em to match something and mount em too
RAINBOWS!!!
https://linustechtips.com/topic/634751-old-hardware-as-wall-art/#findComment-8195785
I like the complexity of the board, and at least it's not an ugly old brown/beige color. That could look pretty cool if you've got a good spot for it.
._.
https://linustechtips.com/topic/634751-old-hardware-as-wall-art/#findComment-8195788
See Im not sure if i want to take out the board though. I kinda want to keep it original. It might not be a bad idea to take everything out and do like anatomy of a server
https://linustechtips.com/topic/634751-old-hardware-as-wall-art/#findComment-8195815
1 hour ago, NumLock21 said:
57 minutes ago, NumLock21 said:
There's even a prettier one. Can't seem to find that pic anymore. Forgot what it's called.
edit: Found it
OMG These are literally the exact desks I was talking about!!!
RAINBOWS!!!
https://linustechtips.com/topic/634751-old-hardware-as-wall-art/#findComment-8196193
People have also made them out of old cpus.
 •E5-2670 @2.7GHz • Intel DX79SI • EVGA 970 SSC• GSkill Sniper 8Gb ddr3 • Corsair Spec 02 • Corsair RM750 • HyperX 120Gb SSD • Hitachi 2Tb HDD •
https://linustechtips.com/topic/634751-old-hardware-as-wall-art/#findComment-8197396
  Hide contents
*Drools*
RAINBOWS!!!
https://linustechtips.com/topic/634751-old-hardware-as-wall-art/#findComment-8197455
