(I have no idea which board to post this topic in)
Hey everyone, I need your help.
I got a bunch of VHS home videos I wanna convert to a digital format. I want the best quality possible, uncompressed quality if possible (since the videos were already poor in quality, I wouldn't want the quality to look even worse than what it already is). What device should I buy? I'd like specific product recommendations please. I have a beefy PC if that matters.
Folding for LTT since April 2016.
https://linustechtips.com/topic/628001-need-help-converting-vhs-to-digital/
3 minutes ago, cleb said:
You could play the vhs and capture from your TV. Not the best idea but I'm curious if there's such a tool too
Theres too many tools out there, most of which I have never heard of, so I have no idea which to use.
Go buy like elgato or something like an HDR and record the Movie/anything you want. Cannot figure out best solution lol. Or plug the vhs tape to your PC and record it from there, I don't know whether or not it would work.
DESKTOP PC :
  CPU :RYZEN 5 2600/ GPU :MSI Ventus OC GTX 1660 Ti/ RAM :Team Elite 2x8/ PSU :Corsair CX650M/ HDD :Toshiba 2TB/ SSD :Adata XPG M.2 SATA 265GB/ COOLER :Be Quite 2x140mm / MOBO :Asus TUF B450 Gaming
LAPTOP :
  CPU :i7-4710HQ/ GPU :GTX 860M/ RAM :8GB OEM/ HDD :1 TB
PERIPHERALS :
  MOUSE :LOGITECH G502/ HEADSET :HyperX Cloud Alpha/ KEYBOARD :Logitech G Pro
POSSIBLE PC BUILD :
  PC PART LINK
I saw that some people had audio sync issues on the Amazon reviews for the elgato video capture
Well, you could have some other HDR devices, do you have digital TV? if yes you could possibly ask one from the company. If not, you could buy one I guess
DESKTOP PC :
LAPTOP :
PERIPHERALS :
POSSIBLE PC BUILD :
  PC PART LINK
https://www.google.ch/search?q=VHS+to+digital+converter&ie=utf-8&oe=utf-8&gws_rd=cr&ei=-OKLV4uVE8HcUfPYidAD
http://www.wikihow.com/Transfer-VHS-Tapes-to-DVD-or-Other-Digital-Formats
You're not going to get a higher quality than what is on those tapes. Garbage in, garbage out.
Guide: DSLR or Video camera?, Guide: Film/Photo makers' useful resources, Guide: Lenses, a quick primer
Nikon D4, Nikon D800E, Fuji X-E2, Canon G16, Gopro Hero 3+, iPhone 5s. Hasselblad 500C/M, Sony PXW-FS7
ICT Consultant, Photographer, Video producer, Scuba diver and underwater explorer, Nature & humanitarian documentary producer
You probably want to buy a high end VHS player they shouldn't be that expensive anymore. Of course on eBay or something similar.
You'll also need a capture card like https://www.blackmagicdesign.com/products/intensity
1.Record it uncompressed
2.edit your recordings(if necessary)
3.compress them with handbrake
I was going to get that, but then I read the horrible reviews on Amazon.
23 hours ago, ALwin said:
Ik how to google search :|
I just don't know which converter to get. Ik I won't get a higher quality. I don't want garbage in, more garbage out. I want the same quality.
even the cheapest crappiest one should not diminish the quality
