Importance of pc cooling for un over clocked PCs
Cankur.007
Hi I have a rig with Skylake core i5 6600 without over clocked and I have no intention of over clocking that in future do I still need to go for a
1)x99 or z97 motherboard will I get any advantage of buying it if I m not over clocking it
2) as I will not be over clocking it do I need to but a better cpu cooler like cooler master Poseidon or anything else or the stock cooler is enough
3) let us assume this problem for any cpu it's already been proved in a Linus YouTube video that higher temperature doesn't effects the performance so why should I spend extra cash for cooling
Noise. If you run the stock cooler under high load, it gets rather noisy. If you use a better cooler on it, it can maintain safe temps without the noise.
Gaming system: R7 7800X3D, Asus ROG Strix B650E-F Gaming Wifi, Thermalright Phantom Spirit 120 SE ARGB, Corsair Vengeance 2x 32GB 6000C30, RTX 4070, MSI MPG A850G, Fractal Design North, Samsung 990 Pro 2TB, Acer Predator XB241YU 24" 1440p 144Hz G-Sync + HP LP2475w 24" 1200p 60Hz wide gamut
Productivity system: i9-7980XE, Asus X299 TUF mark 2, Noctua D15, 64GB ram (mixed), RTX 3070, NZXT E850, GameMax Abyss, Samsung 980 Pro 2TB, random 1080p + 720p displays.
No need for a X or Z motherboard for sure, but regarding the cooler, you don't want the stock cooler even if you're not overclocking for two reasons :
- the noise. Stock coolers are really annoying
- the temperatures. Even if you can't overclock, CPUs tend to get very hot with stock cooler at full load. Having your CPU running regularly at 75-80°C isn't good for its life span. A custom air cooler will also help to get rid of the heat faster, you won't be warming up the rest of the components that way
CPU : i7 8700k @5GHz, GPU : ASUS GTX 1080 Ti STRIX, RAM : 2x8Go 3000MHz Corsair Vengeance, MB : ASUS Prime Z370-A, PSU : CM V850, Case :  NZXT S340, CPU Cooler : NZXT Kraken x62, Monitor : Acer Predator XB271HU 27" 1440p 165Hz, OS : Windows 10 Home 64 bits
Oh, since no one else has mentioned it yet, you can't use X99 or Z97 mobos with the 6600, which needs 100 series chipsets.
Oh yeah, didn't even pick on that Oo
1 hour ago, molude said:
1)No you won't (at least in price to performance).
2)It isn't necessary, but I'd recommend getting an air cooler like the CM Hyper 212 (Both for aesthetics, for the temps and for the noise).
3)None.
Also, you can't possibly OC an I5 6600, only the I5 6600K
Actually it's my mistake I
Actually I liked a b150 gigabyte mother board which has got every thing including m.2ports and nvme support
So I thought that weather I will get any advantage other than over clocking my cpu although I have absolutely no intentions of doing it  getting a higher end motherboard.it will be great if guys help me out
With Z170, it isn't just the CPU OC but the ram OC also. If you never want to OC ram, that's fine. Note there are some Asrock boards that allow limited ram OC even without Z170 chipset.
Let us assume this situation for any other Skylake processor which may be anything that has no k on its end so do those people who have like a 6400 or 6500 or  6100 will they get much much  advantage if they get A high end motherboard
2 hours ago, SageOfSpice said:
1. No.
2. No.
3. Is this even really a question?
What do u mean by is this really a question
I try to mean that if temperatures doesn't effects the performance of the cpu so why should I care for spending an extra for custom Colling
Just the sound or any extra issue if they exists name and explain them
It will come down to the feature set at the end of the day. Does the mobo provide what you need?  If you need something in particular, you may be more likely to find it on a higher end board than a low cost one. If you're looking purely at performance (without overclocking), there will be no real difference.
Sorry mate but having a CPU run at those temps regularly will most likly not have any effect on the lifspan... unless you run it 24/7 on those temps...
I would believe there's more CPU's running the stock cooler than aftermarket ones.. Stock coolers are made to be able to handle the CPU through out its expected lifespan at stock voltages so...
