What's the point of a fan controller?
Solved by STRMfrmXMN,
4 minutes ago, TheSuspect said:I guess to reduce/increase the strength of certain fans, but what's the point of them? How do they even work? I'm a bit ignorant with fan controllers, there's probably a use for them. Enlighten me please
They restrict or allow certain voltage to a fan if plugged in. If you want them to be extra quiet the fan controller severely limits the voltage it sends to the fan. If you want it to run faster to keep your system cooler then it will allow for more voltage. Some fans are not fond of fan controlling however so that's just something to keep in mind.
