I have been looking to upgrade from the aio i have to a custom loop. I have absolutely no experience with custom loops or anything of the type, and was thinking a kit would be a good starting place. I was wondering if anyone had any good recommendations for a kit. This is what I'm considering right now, but wanted other's opinion first. https://www.ekwb.com/shop/ek-kit-s240
https://linustechtips.com/topic/613617-water-cooling-kits/
ek, xspc, alphacool are all good
but you should probably do more research before you spill water over all your PC parts
https://linustechtips.com/topic/613617-water-cooling-kits/#findComment-7929049
I looked at some xspc kits, and I'm considering this one aswell now. http://www.performance-pcs.com/xspc-raystorm-extreme-universal-cpu-watercooling-kit-w-ex240-radiator-420-pump-res.html
Between the ek one i linked before and this one, which is more recommended?
https://linustechtips.com/topic/613617-water-cooling-kits/#findComment-7929082
Try and keep your components from the same brand. While there is no rules against this as they're all usually similar, it just helps to minimise any unforeseen problems.
  • Try to keep your metals the same, if you're using copper - make sure the majority of your fittings are copper (not sure if this is a myth or not, but can be a cause of corrosion if you mix and match. Hence why trying to keep brands similar too.)
  • Use flexible tubing for your first build with compression fittings, it'll make your life easier. I used 3/8 ID, 5/8 OD for my first loop.
  • I would recommend getting a res with built in pump... It's just easier.
  • When you test the loop, make sure that you don't have power to any of the components... Just the power supply and pump. The water used in the loops isn't conductive, so you won't damage anything if there is a leak (but it never hurts to be extra safe).
https://linustechtips.com/topic/613617-water-cooling-kits/#findComment-7929083
Thank for for all the help, but I was more so looking for a kit provided by a company. That way I wont screw up any compatibility, and everything would be guaranteed to work together. Thanks again though.
https://linustechtips.com/topic/613617-water-cooling-kits/#findComment-7929115
The EK kit would be much better with the DDC pump and separate res helping isolate vibration and noise where bay units tend to easily pass vibration into the chassis.
https://linustechtips.com/topic/613617-water-cooling-kits/#findComment-7929274
Agreed.
If you're really scared about screwing something up (I know I would be) you could also consider the EK Predator, their AIO.
QUOTE ME IF YOU WANT ME TO REPLY
Le USD $300 Second Hand Potato
CPU: Intel i5-750 @ 3.8GHz Motherboard: Intel DP55WG RAM: 12GB Corsair Budget 1333MHz (2x2GB+2x4GB) GPU: Sapphire Radeon HD 5750 512MB Case: Cooler Master Elite Storage: Seagate Barracuda 500GB PSU: Cooler Master Generic 500W (came with case) Displays: 21.5" 1080p Acer G226HQL Cooling: Cooler Master Hyper 212 Evo Keyboard: Corsair K70 RGB (Mx Reds) Mouse: Logitech G502 Sound: Turtle Beach X12's Operating System: Windows 10
Yep... My peripherals cost me more than the rig itself. ¯\_(ツ)_/¯
https://linustechtips.com/topic/613617-water-cooling-kits/#findComment-7929446
Well you must do it one time :P
I had no experiences with custom water loops untill last month. Bought kit for it, and I mannaged to get it working. Sure it took me about 4 hours, but in the end nothing was leaking and working as it should. But I spent so many hours because I have small case, and couldn't fit everything inside.
Watch some videon on youtube about water cooling. Some tutorial maybe. I was watching only videos from LinusTech and Jaz2cents. All infos are there :)
btw: I'm using D5 EKWB pump at 60% speed ... can't even hear it. I have to unplug all fans in my case, and I still hardly hear it. If you are 2m away from PC, you won't even know if it's working or not. Dead silent!
Intel i7 12700K | Gigabyte Z690 Gaming X DDR4 | Pure Loop 240mm | G.Skill 3200MHz 32GB CL14 | CM V850 G2 | RTX 3070 Phoenix | Lian Li O11 Air mini
Samsung EVO 960 M.2 250GB | Samsung EVO 860 PRO 512GB | 4x Be Quiet! Silent Wings 140mm fans
WD My Cloud 4TB
https://linustechtips.com/topic/613617-water-cooling-kits/#findComment-7932952
