water I effed up... and I'm on my phone
Solved by Mr.Meerkat,
5 minutes ago, ZillaGames said:It's been literally an hour and the PC is fine now. It turned itself on after I plugged it in (just my motherboard, always does that) about half an hour ago and I didn't realize till the login screen that it was even turned on. I guess it didn't touch any of the components as it really just got into the IO ports in the front of the case. I'm not going to plug anything into it for about two days anyways, so it seems like I'm back up and running. BTW I'm typing this on my PC right now
Fair enough but you never know...better to be safe than having to fork out monies for new parts
